Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Repair information for the 4th Generation iPod shuffle. Released in September of 2010. Model number: A1373.
Вопросов 20 Показать все
What's the cable pinouts?
i have been looking for the pin-outs of the ipod shuffle 4g cable for a day now, and i can't find anything correct, only the 2g witch is apparently not the same one as the 4g. i really need help fast. just to make it easier for you to answer i included a picture, so if you know it please answer
Это хороший вопрос?
Оценка 4
Добавить комментарий
Ответов (3)
Наиболее полезный ответ
Valen S, one of the things to remember is that the Shuffle 4G has a few IC's of unknown type as part of the cable, so we are not sure yet of exactly what they do and how they impact the cable. The pinout itself is as follows ( I am using your markings)
iPod pin 4 to USB pin C => USB DATA - / Left Channel
iPod pin 3 to USB pin B => USB DATA + / Right Channel
iPod pin 2 to USB pin A => GND
iPod pin 1 to USB pin D => Vcc
Hope this helps, good luck.
Был ли этот ответ полезен?
Оценка 5
4 Комментариев:
hmm, weird that nobody has ever taken one apart. the ic stuff is probably a way for apple to earn money :(
из
Yup, that is what makes those cables special and costly ;-)
из
Thanks, guys!!!
из
Did the correct pinout get you comnected or is the PCB necassary to establish a connection?
из
I have found a PCB with several CMD electronic components like IC's, capacitors and resistors inside USB connector of iPod Shuffle 4g cable.
Оценка 1
2 Комментариев:
Hi im making a homemade cable so is it posible to make it witouth these components? please answer ASAP Thank you
из
Did you do it??
из
I followed the pin out and had continuity all around, but my computer didn't recognize it being plugged in and no sign of a charge.
Оценка 0
Добавьте свой ответ
Valen S будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 2
За последние 7 дней: 14
За последние 30 дней: 71
За всё время: 18,256
