Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
The Nokia N9 is a smartphone made by Nokia running on the Linux-based MeeGo "Harmattan" mobile operating system.
Screen is cracked and it won't turn on
I have a cracked screen nokia n9 is there anyway to fix a phone like that? It's an internal memory phone the screen is broke and it won't turn on.
Это хороший вопрос?
Оценка 3
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
I think you may have damaged your LCD while dropping it or the cable became undone.
Был ли этот ответ полезен?
Оценка 1
you can replace the display assembly on a nokia n9. all steps are detailed in nokia service manual.
most of the time a nokia n9 that will not turn on is due to a discharged battery. you can force charge it by using flasher utility.
start the flasher utility, then plug your device and do nothing else but wait. this is a trick to force charge of a nika n9 battery was discharged too low. consider replacing the battery if this happens often.
Оценка 0
Добавьте свой ответ
Collin Johnson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,241
