Xiaomi Mi 3 — это высококлассный смартфон премиум-класса на базе Android, выпускаемый компанией Xiaomi.
retrieve pictures locked screen
Okay so i went to China bought a xiomi phone, dropped it in water and didnt have rice to let it lie there. Many hours later, the phone is dry and turns on when powerkey pressed but screen is iresponsive.
Is it possible to still retrieve my pictures if i had a password. If i reboot it will i lose m'y pictures? What should i do?
If i bring you m'y phone could you open it and fully repair it even with Walter damage? Also, it vas been a few months so i forgot my password. Thankyou
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible if you can from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Here is a link to the Ifixit guide on how to dis-assemble your phone.
Xiaomi Mi 3
Hopefully after you have done all this the phone might possibly work correctly again and you can retrieve your pictures. Although since it happened a few months ago it may not be successful.
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Also for your future reference (hopefully not necessary) this may be a some value to you.
Don't Put Your Device in Rice. Here's Why...
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
belle4011 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 30
За все время: 410
