Android-смартфон Huawei Ascend Y600 оснащен дисплеем с разрешением 480x854 и процессором с тактовой частотой 1,3 ГГц. Выпущен в июне 2014 года.
Huawei y600 got wet
What is the solution when mobile phones got wet?
Это хороший вопрос?
Счет 1
1 Комментарий
Do not try to power on and remove battery asap. then follow Jimfixer answer.
из
Добавить комментарий
1 ответ
Выбранное решение
Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning. Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best. This may be helpful . Hope this helps
Был ли этот ответ полезен?
Счет 4
Добавьте свой ответ
arnoldgriarte буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 19
За всё время: 643
