Western Digital My Passport Ultra — это портативное устройство хранения данных с интерфейсом USB 3.0 и емкостью от 500 ГБ до 5 ТБ.
Dropped portable hard drive
I dropped my portable external hard drive. Can I still recover all the files inside my external hard drive?
Это хороший вопрос?
Счет 9
2 Комментариев
my WD is dropped and whenever i plug in it asks me to format the Drive G? so is it possible to recovery my files back ?
из
I dropped my My Passport Ultra, and is makes a whirring sound, but does not link up with my computer. Can I recover my data on the disk?
из
Добавить комментарий
5 Ответов
Выбранное решение
Is this the ssd version or hard disc? If its the hard disc will it power up does it click? If it clicks you can make it work enough to recover data. This video may help
https://www.youtube.com/watch?v=F5Y7Bnia...
Try to be as clean as possible when preforming the task of opening the hard drive . Try to keep dust to a minimum.
Был ли этот ответ полезен?
Счет 3
5 Комментариев:
The power up still functioning but i doesn't blinking and also i hear a noise inside the disc beeping.
из
Can i still recover all the files in my portable external hard drive?
из
Fix for a beeping hard drive https://www.youtube.com/watch?v=7m5cil6K...
Once you get it to work make a copy of your important file odds are it wont last long
из
yea i dropped my one an it has the click of death nowso imtryin to copy as much as i can will this &&^& it up?
из
what if it doesn't click, but lights blink and whirring sound inside, sometimes it lets me unlock but won't go any further
из
It is possible the data can be recoverable, however you need to make sure NOT to plug it in anymore and send it to a Certified data recovery company for help. mobdro app
Счет 0
It is possible the data can be recoverable, however you need to make sure NOT to plug it in anymore and send it to a Certified data recovery company for help. [http://<a href="https://mobdrotvapk.com/">mobdro</a>|mobdro]
Счет 0
My WD passport fell on the floor…now there is a clicking sound and not loading once plugged into device… how can I retrieve files from the external hard drive
Счет 0
1 Комментарий:
Did you fix a fix?
из
Hello, today I dropped my 1TB Western Digital MyPassport, the cover came apart and the drive was exposed. It re-assembled just fine, it switches on when plugged in just fine, it sounds how it ordinarily would when plugged in, but is not loading on Windows and is no longer accessible via the Windows File Explorer.
I can select the option to safely remove the USB device however, which is strange. So essentially the OS recognises it in that regard, but the files themselves can't be accessed...
Not sure if this would affect it, but it was nearly full to capacity with only a few GB free.
Can anyone provide advice on what I should do, or know of a good recovery provider in London UK?
Счет 0
Добавьте свой ответ
Carl Pastoril буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 9
За последние 30 дней: 29
За всё время: 95,813
