Ремонт и техническая поддержка потолочных вентиляторов с лопастями.
Ceiling fan not responding to remote control
Grandson played with remote control, with a finger on each of the hi & low speed buttons simulataneously, jiggling them. Fan now only runs at high speed & does not respond to medium or low speed buttons. Have replaced battery.
Update (12/26/2017)
The make is Lucci air On the back of the remote is the number FCCID CHQ 70307
Это хороший вопрос?
Счет 1
4 Комментариев
where is the controller?
из Поделиться
The fan stopped working despite completely working remote and fan able to respond with the main switch
из Поделиться
@aryaan
What is the make and model number of the fan?
из Поделиться
If you happen to have a Harbor Breeze Calverton, the solution is to turn power off for 30 seconds. Then turn the power on and immediately press and hold the power button on the remote for 5 seconds. The main light will blink twice, at which time you remote should be resynchronized. This worked for me.
из Поделиться
Добавить комментарий
4 Ответов
Выбранное решение
Have a look on the control for a reset switch (hole). If present reset controller. Otherwise post make and I'm sure someone will know if there is a button code to use.
Был ли этот ответ полезен?
Счет 0
4 Комментариев:
My remote will not turn off light or fan off or do any speed changes
из Поделиться
@geoffwilli12388
Do the control switches for the fan work OK? Most remote controlled fans also have manual on/off/speed switches wired to them as well.
из Поделиться
I have tried fitting new battery.
из Поделиться
I found this guide to be helpful with this problem
https://smartceilingfan.com/ceiling-fan-...
Let me know if it is helpful for you as well!
- Ceiling Fan Guru
из Поделиться
Наиболее полезный ответ
Hi @chandrakathy,
Mostly the controller (receiver) is located in the housing of the ceiling fan.
Disconnect the power for the fan by removing the fuse in the power box and then access the ceiling fan housing.
Be safety aware you will be working with lethal voltage circuits! If there is no separate fuse marked for the fan then perhaps it is connected in with the lights fuse. If the fan was not working at all so that you can’t verify that it has no power connected by trying to turn it on and off after having removed the fuse, then take no chances and operate the house main power isolating switch or remove all the main household side power and light supply fuses in the power box. If in any doubt contact an electrician. It’s not worth doing it yourself, your life is worth more.
You don’t state the make and model but there are normally some screws that can be undone to access the wiring etc.
Here’s the ifixit Замена светильника потолочного вентилятора guide.
The images shown at Step.2 in the guide (hover mouse over right side image) give you a rough idea where to look for the controller.
Счет 1
If your ceiling fan has stopped working, there are a few possible reasons why. First, check to make sure that the power is turned on at the circuit breaker. If the power is off, flip the breaker switch to the on position and see if the fan starts working. If the power is on and the fan still isn't working, it's likely that a fuse has blown or there is a loose wire. Check the fuse box and replace any blown fuses. If there are loose wires, tighten them with a screwdriver. If none of these solutions work, you may need to call an electrician. learn more ceiling fan solutions here
Счет 0
1 Комментарий:
My fan is not working
из Поделиться
Счет 0
Добавьте свой ответ
Carmen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 55
За последние 30 дней: 243
За все время: 51,352
