Смартфон LG G4 был выпущен в США в начале июня 2015 года. Как всегда, производитель уделил основное внимание высококлассным характеристикам и изысканному дизайну, который выделяет устройство на рынке премиальных смартфонов. Каждая версия телефона имеет свой номер модели, в зависимости от того, продается ли она оператором связи или является разблокированной (для рынка США или международной версии). Некоторые модели LG G4 подвержены проблеме «циклической перезагрузки» (bootloop).
Phone not accepting Sim Card
So my old LG G4 (H815 Factory Unlocked) isn't playing ball with my Boyfriends 3 Sim. The phone is confirmed Unlocked and I've been able to use my GiffGaff sim in the phone which further confirms it's unlocked. However it refuses to accept a 3 sim (Both my new 3 Sim; his and one from the store)
I've tried factory resetting the phone a number of times, rebooting, opening it up and inspecting the prongs. Nothing; any advice?
I've also fiddled with APN settings and LTE/GSM settings.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
While this is likely a hardware issue with the cellular radio, try another SIM card. It doesn't need to work, so use a dead SIM that's been deactivated or an expired T-Mobile SIM. The other option is to buy a prepaid SIM card kit from Net10 or Tracfone since the phone isn't carrier locked.
If you continue having issues, there's a problem with the cellular radio or SIM slot. If you're comfortable with board level repair, you can try to troubleshoot further. f you are not, then you're going to need a new motherboard.
Был ли этот ответ полезен?
Счет 4
4 Комментариев:
See, I failed to mention that it did detect the sim once, it had a data value but no connection. I think a motherboard replacement may be in order though.
из
That could mean the SIM is inactive. If you know with 100% certainty it's active then it might be the board.
из
Sim is 100% active; it's been working in another phone. Sounds like a mainboard issue
из
Sim card not working other phone simcard is working
из
Добавьте свой ответ
Finlay буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 16
За все время: 7,495
