XP-410 оснащен новейшими стандартами беспроводной связи, а также Wi-Fi Direct1. Кроме того, он поддерживает Apple® AirPrint™ и Google Cloud Print™. Встроенные слоты для карт памяти, ЖК-дисплей диагональю 2,5 дюйма и удобная сенсорная панель позволяют легко печатать фотографии без полей и с индивидуальными настройками в различных макетах без использования компьютера.
My printer is will not print.
My Epson XP-410 printer will not print. Says it must be connected to the WiFi which it is. I have installed a new driver and updated the firmware. When doc is put in queue is says error. This printer is the default. What do I do next?
Это хороший вопрос?
Счет 3
1 Комментарий:
Add new cartridge and still says it needs a new one
из
Добавить комментарий
2 Ответов
Make sure both printer and computer are on the same network, ( wireless). if they are add the printer to the computer and it should work. if not visit the printers’s website for install support. https://epson.com/Support/Printers/All-I...
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
you should also check the printer IP and that of the PC driver property box... they must be the same... most of the time this error occurs when you are connected through LAN or Wireless... i will suggest you try printing through USB connection
из
Are you using 3rd party ink? Epson is starting to pull a Lexmark with 3rd party ink carts and blocking them in firmware. This is happening on the small black cart printers and the traditional sized black cart ones.
PRAY you can get into recovery mode and downgrade the firmware to a revision that’s 2-3 versions old if you can find it, as Epson pulls old firmware to screw people into buying their ink. NEVER UPDATE EPSON FIRMWARE ON BLACK CART MODELS. Stick to a 3rd party safe firmware and DO NOT do it again. Hopefully you can use these instructions to downgrade the firmware.
Счет 0
Добавьте свой ответ
Katy Waters буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 3,189
