Vacuum does not hold charge
Dyson V6 Absolute after being on charge for 24 hours only runs for about 15 seconds when you use it, how can this be fixed?
Это хороший вопрос?
Это хороший вопрос?
If your Dyson v6 Absolute vacuum cleaner unexpectedly turns off during use, see the Dyson v6 Absolute Shuts Off While In Use problem page for possible causes and solutions.
If your Dyson v6 Absolute vacuum cleaner’s battery life is not long enough to complete a vacuuming task, see the Dyson v6 Absolute Battery Life Is Too Short problem page for possible causes and solutions.
Был ли этот ответ полезен?
Unfortunately , the answer is to buy a new one. I'm quite the techy kind of girl and I completely dismantled my vacuum every screw every seal everything that could be removed. I did a spit shine and polish and still nada. So I ordered a new battery and charger. Voila, it worked....for another year.Now it lasts 10 seconds turns off and readily turns back on for increments of 3 sec. It will keep turning on indefinitely for 3 sec each time so the battery is not dead. Again Ive disassembled the entire machine. Nothing is stuck, nothing is plugged. Its cleaner inside than when I bought it. I'm NOT investing another $100 in a new battery. I'm investing in a Bissell stick, a name wayyyy older than Dyson
I cleaned the filter and then it worked perfectly!
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 3,216
Hi john7291
What is the frequency do you use it? everyday ? and how long it is with you?
What other options had you tried?
You mentioned that only 15 Seconds and it went flat, did you try charging again and test like maybe after one hour of charge.
из Augustine
