Spacebar cracked, how do I replace?
Was trying to remove the spacebar to clean and it cracked. Where do I get a new one and how do I replace it properly?
Это хороший вопрос?
Это хороший вопрос?
Hi ,
You may be able to fix it yourself.
Here’s a link that will help with this. Select your key and key type
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 20
За всё время: 554
4 Комментариев
Is this an internal laptop keyboard or a separate desktop keyboard?
из Ken Grubb
William Waite your computer is a Dell Alienware 15 R3?
из oldturkey03
Duh, I see it now. Have you reached out to Dell to see how much a replacement keyboard is? That helps in computing a repair. It should also get you to install instructions to help you removing the keyboard to look at whether and how you can repair it.
из Ken Grubb
Internal keyboard. Yes, Alienware m15 r3 I believe. I have not contacted Dell. Taking it to a repair shop tomorrow for analysis and estimate.
из William Waite
