Четвертое поколение умных часов Apple с опциональным сотовым модулем, выпущенное 21 сентября 2018 года.
What is this part for?
I’m 13 years old and trying to take responsibility for breaking my Apple watch by fixing it myself.
I have the screen replacement, but this part came out of my watch. I think it is the force touch sensor, but I wanted to double check.
EDIT: My screen replacement is below. It is off-brand.
If possible could I get some help?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
If you review Step 8 in this Teardown of the Watch you’ll see the pictured part is not the ForceTouch sensor Разборка Apple Watch Series 4
As to what it is would be tough as there is not enough information in the image to gain a sense of scale or understanding the parts construction.
Using the teardown can you see what it is.
Update (03/05/2023)
@ebp049x - OK, was out enjoying the day sorry for not piping up sooner.
The display assembly is made up of a collection of discrete elements the crystal glass, the touch plate, the OLED screen, the backplate which holds the NFC chip.
What I see is a bunch of mangled parts and you still have part of the display assembly attached to the watches body.
You will need to get a new display assembly to fix this. Here’s the guide which also has the parts info Замена экрана Apple Watch Series 4
Apple Watch Series 4 Изображение
Инструкция
Сложность:
Умеренно
Apple Watch Series 4 Экран Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
Был ли этот ответ полезен?
Счет 0
7 Комментариев:
It is part of the screen, which is not disassembled in the teardown.
из
That's the touch screen. Don't worry about it.
из
If I do not reapply it or do not purchase a replacement, will anything on the watch be affected?
из
@ebp049x That is already on the replacement screen. Nothing to worry about. Good luck with the repair.
из
I posted an update
из
Показать ещё 2 комментариев
Добавьте свой ответ
Eshaan Bhargav Patel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 23
За всё время: 455
