Apple Watch Series 4 Screen Replacement
Выберете то, что вам нужно
    1. Apple Watch Series 4 Screen Replacement, Display Opening: шаг 1, изображение 1 из 2 Apple Watch Series 4 Screen Replacement, Display Opening: шаг 1, изображение 2 из 2
      Спросите у FixBot
      Добавить комментарий
    2. Apple Watch Series 4 Screen Replacement, Safety Requirements: шаг 2, изображение 1 из 3 Apple Watch Series 4 Screen Replacement, Safety Requirements: шаг 2, изображение 2 из 3 Apple Watch Series 4 Screen Replacement, Safety Requirements: шаг 2, изображение 3 из 3
      • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
      • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
      • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
      • Wear eye protection. The knife or glass may break, sending pieces flying.
      • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
      Спросите у FixBot
    3. Apple Watch Series 4 Screen Replacement: шаг 3, изображение 1 из 1
      • Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
      • Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
      • You may need to reheat the iOpener and repeat this procedure several times until the display adhesive gets loose enough.
      Спросите у FixBot
    4. Apple Watch Series 4 Screen Replacement: шаг 4, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 4, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 4, изображение 3 из 3
      • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
      • Press firmly straight down into the gap.
      • Once inserted, tilt the blade to pry the display open slightly.
      • Do not insert the knife more than 1/16th of an inch (~2 mm) to avoid damaging the Force Touch sensor.
      Спросите у FixBot
    5. Apple Watch Series 4 Screen Replacement: шаг 5, изображение 1 из 2 Apple Watch Series 4 Screen Replacement: шаг 5, изображение 2 из 2
      • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
      • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
      • Don't try to fully open or detach the display yet.
      Спросите у FixBot
    6. Apple Watch Series 4 Screen Replacement: шаг 6, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 6, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 6, изображение 3 из 3
      • It's likely that the Force Touch sensor will stick to the display frame instead of the watch's body. In this case, insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
      • To preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
      • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
      • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm) to avoid damaging other components.
      Спросите у FixBot
    7. Apple Watch Series 4 Screen Replacement: шаг 7, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 7, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 7, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      • To avoid straining the display cables, don't open the display all the way yet.
      • Open the display at max. to an 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
      • Thread the adhesive around and behind the display cables to get it off completely. Since the adhesive needs to be replaced anyway, you can cut it if that makes removal easier for you.
      • Make sure to return to this point during the reassembly of your watch and then continue with the Resealing Procedure.
      Спросите у FixBot
    1. Apple Watch Series 4 Screen Replacement, Battery: шаг 8, изображение 1 из 2 Apple Watch Series 4 Screen Replacement, Battery: шаг 8, изображение 2 из 2
      • Carefully fold the screen to the back until you get enough space to pry out the battery.
      • Avoid tensioning the display cables when folding the screen to the back.
      • Insert an opening pick between the battery and the Taptic Engine.
      • A regular opening pick works fine with the 44mm version of the Apple Watch Series 4. However if you own the 40mm version and don't have enough space you can customize your opening pick with scissors.
      Спросите у FixBot
    2. Apple Watch Series 4 Screen Replacement: шаг 9, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 9, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 9, изображение 3 из 3
      • Slide the opening pick along the edge of the battery to loosen the adhesive.
      • The adhesive which holds the battery in place is soft. However, if you're struggling to pry out the battery you can place a heated iOpener on the rear side of the watch to loosen the adhesive. Apply the iOpener for at least two minutes.
      • Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the system board.
      • Mind the display cables and especially the Force Touch cable which covers the battery in one corner so you don't damage them when levering the battery out.
      • Make sure you don't puncture or deform the battery, as it can catch fire and/or explode if damaged.
      • Don't try to remove the battery all the way yet. It is still connected to the watch assembly.
      Спросите у FixBot
    3. Apple Watch Series 4 Screen Replacement: шаг 10, изображение 1 из 2 Apple Watch Series 4 Screen Replacement: шаг 10, изображение 2 из 2
      • Carefully lift the battery and bring it in a 75° angle.
      • Use a pair of tweezers to peel the black sticker off the metal plate which covers the battery connector.
      Спросите у FixBot
    4. Apple Watch Series 4 Screen Replacement: шаг 11, изображение 1 из 1
      • Remove the Y000 screw (1.2 mm length).
      Спросите у FixBot
    5. Apple Watch Series 4 Screen Replacement: шаг 12, изображение 1 из 2 Apple Watch Series 4 Screen Replacement: шаг 12, изображение 2 из 2
      • Use a pair of tweezers to remove the metal plate which covers the battery connector.
      Спросите у FixBot
    6. Apple Watch Series 4 Screen Replacement: шаг 13, изображение 1 из 2 Apple Watch Series 4 Screen Replacement: шаг 13, изображение 2 из 2
      • Use the pointed end of a spudger to pry up and disconnect the battery flex cable.
      Спросите у FixBot
    7. Apple Watch Series 4 Screen Replacement: шаг 14, изображение 1 из 2 Apple Watch Series 4 Screen Replacement: шаг 14, изображение 2 из 2
      Tesa 61395 Tape
      $8.95
      • Remove the battery.
      • Be sure to remove the protective liner to expose the adhesive on your new battery before you set it in place.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • If you are reusing your old battery during reassembly, you can reuse the existing adhesive to secure the battery during reassembly. Alternatively, remove the old adhesive with high isopropyl alcohol and a lint free cloth and use a small piece of double-sided tape such as Tesa 61395, or a dab of liquid adhesive such as E6000.
      Спросите у FixBot
    1. Apple Watch Series 4 Screen Replacement, Screen Removal: шаг 15, изображение 1 из 2 Apple Watch Series 4 Screen Replacement, Screen Removal: шаг 15, изображение 2 из 2
      • The black foil which covers the display connectors is very fragile and likely to rip. To keep the tape intact while peeling it off, it's necessary to use high isopropyl alcohol or an iOpener.
      • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip and apply it to the black adhesive foil. Let it penetrate the adhesive for about two minutes.
      • Alternatively you can place an a heated iOpener on top of the screen to loosen the adhesive. Apply the iOpener at least for two minutes.
      Спросите у FixBot
    2. Apple Watch Series 4 Screen Replacement: шаг 16, изображение 1 из 1
      • Use a pair of tweezers to carefully peel off the tape covering the three display cable connectors.
      Спросите у FixBot
    3. Apple Watch Series 4 Screen Replacement: шаг 17, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 17, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 17, изображение 3 из 3
      • Use one arm of a pair of tweezers to carfully open the three ZIF connectors on the rear side of the screen.
      Спросите у FixBot
    4. Apple Watch Series 4 Screen Replacement: шаг 18, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 18, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 18, изображение 3 из 3
      • Use a pair of blunt nose tweezers to peel up the sides of the black foil which adheres the cable to the rear side of the screen.
      Спросите у FixBot
    5. Apple Watch Series 4 Screen Replacement: шаг 19, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 19, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 19, изображение 3 из 3
      • Lift the body of the watch up and carefully slide a spudger underneath the display flex cable to loosen remaining adhesive.
      Спросите у FixBot
    6. Apple Watch Series 4 Screen Replacement: шаг 20, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 20, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 20, изображение 3 из 3
      • Carefully pull the display flex cables out of their ZIF connectors.
      • Make sure to hold on to the display flex cable during this procedure and avoid pulling only on the body of the watch. Otherwise the display cable might rip.
      • Separate the watch assembly and the screen.
      Спросите у FixBot
    1. Apple Watch Series 4 Screen Replacement, Screen: шаг 21, изображение 1 из 3 Apple Watch Series 4 Screen Replacement, Screen: шаг 21, изображение 2 из 3 Apple Watch Series 4 Screen Replacement, Screen: шаг 21, изображение 3 из 3
      Adhesive Cleanup Kit (Set of 12)
      $7.99
      • The following steps describe how to apply replacement adhesive before reassembling your watch.
      • Apply a little bit of high isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on top of the Force Touch gasket.
      Спросите у FixBot
    2. Apple Watch Series 4 Screen Replacement: шаг 22, изображение 1 из 1
      • Use a pair of tweezers to carefully remove the replacement adhesive with the blue protective film from the backing paper.
      Спросите у FixBot
    3. Apple Watch Series 4 Screen Replacement: шаг 23, изображение 1 из 3 Apple Watch Series 4 Screen Replacement: шаг 23, изображение 2 из 3 Apple Watch Series 4 Screen Replacement: шаг 23, изображение 3 из 3
      • Hold the replacement adhesive diagonally to thread it over the display cable.
      • Position the replacement adhesive on top of the Force Touch gasket.
      Спросите у FixBot
    4. Apple Watch Series 4 Screen Replacement: шаг 24, изображение 1 из 1
      • Use the pointed end of a spudger to make final position adjustments and press the adhesive into place.
      Спросите у FixBot
Заключение
To reassemble your Apple Watch Series 4 follow these instructions in reverse order to reattach the screen and the battery.
37 человек успешно провели ремонт по этому руководству.
Dominik Schnabelrauch
Участник с: 11/23/16
262 916 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 63 339 руководств
17 Комментарии к руководству
Do not buy does not come with all the pieces needed to make the screen repair all the connections are not possible
jachs780 - Ответить Поделиться
Can you tell me what the black adhesive tape with flex ends that covers the flex ribbons is used for and can it be replaced ?
Sheila Blackwell - Ответить Поделиться
That is for shielding and grounding purposes. If you get a spare you can of course replace it. But be careful not to damage the display cables.
Tobias Isakeit - Ответить Поделиться
Sheila, this you can purchase on Aliexpress. i tried to get it elsewhere, seems noone else stocks it. cost approx $10. i found it here: https://www.aliexpress.com/item/10050019...
palokiller - Ответить Поделиться
I have replaced an original screen from another apple watch and everything seems to have gone well. But when I try to pair with the iphone it doesn't succeed. Is it because I didn't put the NFC chip from the original apple watch? What can be?.
It is an apple watch series 4 44 mm + cellular.
Thank you very much.
ihsack - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 34
За последние 7 дней: 164
За последние 30 дней: 761
За всё время: 168,471
