No Power when Plugged into outlet.
Bought a 2019 anova precision cooker bt wifi. Used only twice. Used yesterday. Went to use it again today and I get nothing powering up when plugged in. No visible switch or fuse. Tried three direct wall outlets but still zero power. Is this fixable I am sure as hell not dumping another $180 to replace it!!!
What would be the most likey cause for no power? Is this fixable?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @richardmulawa
There's a fuse shown in Step 4. of the ifixit Разборка Anova Precision Cooker BT WiFi guide.
Select the small image, 3rd to the right at Step.4 to see its location.
If it is blown, then as to why this occurred would have to be further investigated. Fuses do not usually fail for no reason
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Richard Mulawa буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 20
За всё время: 1,534
