Water damage, any help
Phone fell in water and taken out in a few minutes but won’t turn on. It’s a Tecno Spark Go 2021 (KE5). Any help?
Это хороший вопрос?
Это хороший вопрос?
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a video that may help, at least to gain access to all the components
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
@jayeff help me my phone closed it self randomly and its refusing to open itself it shows thats its charging but it cant open it self
Has it gotten wet at all? If it has see the answer above for what to do.
@jayeff no it hasnt goteen wet at al its finish battery so fast it closed it self at 70%
@jayeff can i have ur instagram so i can explain well
".... its finish battery so fast it closed it self at 70%", does this mean that it switches off whilst it is charging?
What happens if you turn the phone off and just try charging it? Does it get to 100%?
Hi @alitech466,
See the Most Helpful Answer above for what to do
За последние 24 часов: 16
За последние 7 дней: 25
За последние 30 дней: 49
За все время: 674
3 Комментариев
Phone ki battery Kam nahin kar rahi hai
=== Update (10/08/24) ===
Bettry problem
из Tecno ke5
Phone ki battery Kam nahin kar rahi hai phone ki battery Kam nahin
из Tecno ke5
yoo can anyone help me my tecno spark 2021 randomly closed it self and it stayed like 2 to 3 months without charging,It get to 100% faster but it removes power fast anyone whats the problem
из Atwich Aweer
