Samsung Galaxy Tab S7+ (SM-T970), выпущенный 18 сентября 2020 года, представляет собой более крупную и мощную версию Tab S7. Он оснащен 12,4-дюймовым дисплеем Super AMOLED и процессором Qualcomm Snapdragon 865.
Display issues after water damage
My tablet would not turn on at all after getting wet, but after sitting around for a few months it now boots up. However, the display has areas that flash bright white making it very difficult to use. I sent it into Samsung for repair (when it wouldn't turn on), but they quoted $1200 for repair which didn't seem worth it. I'm wondering if anyone might know which components need to be replaced to fix a display problem like this?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @davidleckenby
Given the length of time since the water entered to tablet, hopefully it is not too late, but you can only try.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the tablet's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your tablet and then remove the battery as soon as possible from the tablet to minimize any further damage.
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
From your description you may have to replace the display assembly but perhaps check the tablet's operation after you have thoroughly cleaned everything as described above, as this will give a better idea of what is working OK and what is not.
Here is the ifixit Samsung Galaxy Tab S7+ repair guide that may help
If this process seems too daunting, take your tablet to a reputable, professional electronics or mobile phone repair service, experienced in liquid damage repair and ask for a quote for a repair.
Был ли этот ответ полезен?
Счет 3
1 Комментарий:
Thanks for the detailed response @jayeff. I will try your cleaning suggestion and see how that goes.
из
Добавьте свой ответ
David Leckenby буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 667
