15,6-дюймовый ноутбук с экраном FHD 144 Гц, процессором Intel i5-13450HX, видеокартой RTX 3050 6 ГБ, 8 ГБ оперативной памяти DDR5, SSD на 512 ГБ, ОС Windows 11, аккумулятором 60 Вт·ч и блоком питания на 170 Вт.
How do I clean the fans?
My LOQ 15IRX9 fans haven't been cleaned since it was bought, and I can see some dust building up on its bottom cover. I want to know how I can clean the fans on the inside by myself. How do I do it properly?
Это хороший вопрос?
Счет 3
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @kialzi
Here's the hardware maintenance manual for the laptop.
Go to p.42 in the manual (48 of 68 pdf) to view the procedure to remove/replace the thermal module.
Once it's removed this will allow you gently clean the fans away from the other components inside the laptop.
Also once it has been removed, check the condition of the thermal paste on both the CPU and the GPU to make sure that it hasn't dried out and needs to be refreshed.
Here's the ifixit Нанесение термопасты guide that may help with this.
Был ли этот ответ полезен?
Счет 2
Open the laptop up(just unscrew everything on the back and use a small pick (can be a guitar pick) to open it and then just vacuum the dust out
You can also put a new SSD in (2242 or 2280)
Счет 0
Добавьте свой ответ
Kialzi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 23
За последние 30 дней: 172
За всё время: 2,202
