Информация о ремонте и разборке электронной читалки Libra Colour от Rakuten Kobo, выпущенной в апреле 2024 года. Идентифицируется по номерам моделей N428 или N428B.
Is it a software or hardware issue? Image attached
Hello! When I took my eBook out of its case, the screen looked like this. It has been exactly one year and one week since I bought the device, so it’s no longer under warranty.
I need help to know whether you think the screen is broken and I should buy a replacement and repair it, or if it could be a software issue.
I haven’t dropped it or hit it, but it was inside my backpack.
Thank you very much!
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
yes that is a broken display, it would need to be replaced.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Thanks a lot! wish me luck replacing the screen by myself hahaha
из
@isdt good luck! use heat and 99% isopropyl alcohol (in small bits), it may help loosen the adhesive.
just make sure to check and see if the displays come as a digitizer with the display, or separately. some devices are laminated together and you cant just replace one or the other and both need to be replaced as one piece.
из
Hi @isdt
The screen is broken and will need to be replaced.
Depending on which model you have here are the ifixit Замена экрана Kobo Libra Colour (N428) and the Замена цветного экрана Kobo Libra guides that will help.
If you have the N428 variant, then ifixit have the screen assembly in stock but not for the N428B version it seems.
Kobo Libra Colour N428 Экран Изображение
Инструкция
Сложность:
Умеренно
45 minutes - 1 hour
Kobo Libra Colour N428B Screen Изображение
Инструкция
Kobo Libra Colour (N428B) Screen Replacement
Сложность:
Умеренно
1 - 2 hours
Счет 0
Добавьте свой ответ
ISDT буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 19
За всё время: 173
