NO Power comnpletely dead
Chilicube has no power. Completely dead. Thermal cutout switch appears not to have tripped as i have tried resetting. Any ideas Thanks.
Это хороший вопрос?
Это хороший вопрос?
Disconnect the power to the device and use a DMM's (digital multimeter) Ohmmeter function to check if the line input fuse F1 has been blown.
Here's a composite image taken from Step.9 of the ifixit Разборка ChiliTechnology ChiliCube guide showing where the fuse is located.
If it has blown unfortunately I can't zoom in close enough on the image to read the specifications that are printed on the fuse case. You may have better luck. If you go to order a replacement get 2 or 3 as fuses generally don't fail of their own accord. If the replacement fuse also fails then the reason for this will have to be found.
(click on image)
Был ли этот ответ полезен?
Thanks for the info. I will let you know how i progress.
Fuse is good. So still looking.
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 39
За все время: 128
