Akai MPK25 Keys Replacement
Введение
Перейти к шагу 1Use this guide if any of the keys are broken, chipped, or stuck.
Выберете то, что вам нужно
Запчасти
Инструменты
Показать больше…
Using needle nose pliers, remove the washers from the four corner selector knobs.
Flip the device over. Using a Philips #2 screw driver, remove the fourteen 10.3 mm black screws holding the back panel in place.
Carefully flip the device to the front making sure you secure the face plate and the chassis together.
Rotate the device 180 degrees and carefully remove the face plate by slightly lifting the screen side towards you and then sliding the bottom out from under the keys.
Using needle nose pliers, grip the top of the spring coil, that is holding down the key, and gently lift the spring away from the key.
Lift the key from the front of the keyboard towards the back in order to remove it completely.
To reassemble the keyboard and close up the case, follow these instructions in reverse order.
7 человек успешно провели ремонт по этому руководству.
