Alcatel One Touch Idol 3 Battery Replacement
Введение
Перейти к шагу 1This guide will show you how to replace the battery from a Alcatel One Touch Idol 3. Replacing your phone battery can breath new life into your phone by improving battery life and sometimes performance as well.
Before you start make sure to power off the phone.
Выберете то, что вам нужно
Инструменты
Remove the sim tray by inserting a sim removal tool and then pulling it out.
Remove the back cover by moving around its perimeter with a thin object that can fit.
Eventually you will be able to pry open the back cover.
Add a small amount of isopropyl alcohol around the sides of the battery to soften the adhesive.
Pry out the battery by leveraging an object under the battery and lifting it upwards.
