Asus MeMO Pad 8 ME181C Battery Replacement
Введение
Перейти к шагу 1Use this guide to replace a faulty battery in you ASUS MeMO Pad 8.
Выберете то, что вам нужно
Инструменты
Insert a plastic opening tool into the seam between the rear case and the screen.
Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
7 человек успешно провели ремонт по этому руководству.
2 Комментариев
Great instructions and easy disassembly/reassembly. Photos really helped!
