Asus Transformer Pad TF103C Rear-Facing Camera Replacement
Выберете то, что вам нужно
Make sure the power is off.
Insert the plastic opening tool into a crack on side of the tablet.
Carefully pull the tool upwards to and pry open the Transformer pad.
Slide the tool in the gap along all four sides, continually pulling the tool upwards.
Remove the back cover once it is loose and set it aside.
Rotate the tablet so it matches the picture.
Carefully unplug the battery cable from the motherboard by grabbing the wires close to the black piece and pulling it out of the housing.
Remove black tape from ribbon cable and separate the cable from the soundboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove black tape.
Unplug ribbon cable using small tweezers from volume and power button.
Lift up the motherboard.
Pull out ribbon cable from the underside of the motherboard then remove it.
To reassemble your device, attach the new camera to the motherboard then follow these instructions in reverse order.
