Canon EOS Rebel XS LCD Replacement
Введение
Перейти к шагу 1Use this guide to replace the LCD. The LCD tends to fade after about five years.
Выберете то, что вам нужно
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
Pry up the panel; starting from the front/bottom corner, as indicated.
There's a concealed lip, under the opposite edge.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
Use tweezers to lift the panel.
Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
Use the tweezers to gently remove the straps (in the teal box).
Use the Phillips Screwdriver to remove the four screws (in the red dots).
Use your fingers to remove the silver plate.
Use the Spudger on the edges of the screen.
Once one end is lose, use the tweezers to lift the screen.
3 человек успешно провели ремонт по этому руководству.
