Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Cloth Face Mask Nose Bridge Replacement
Kayla Vargas
Kayla Vargas и еще один участник
Последнее обновление February 27, 2025
10 - 30 минут
Легко
Face masks have become an essential part of everyday lives. Some have taken to crafting their own cloth face masks. The issue is that they lack stability and are susceptible to forming fog on glasses. A solution to this is adding in a nose bridge made of pipe cleaners! Once done, you will have an extra layer of protection when wearing your cloth mask.
  1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: шаг 1, изображение 1 из 2 Cloth Face Mask Nose Bridge Replacement, Nose Bridge: шаг 1, изображение 2 из 2
    • It's best to wash your mask before and after handling to ensure cleanliness.
    • Lay the mask flat on desired surface.
    • Optional: Steam mask with a clothing iron to completely flatten and remove wrinkles.
    • Caution: Never leave the clothing iron unattended. Use caution when ironing as the machine will be hot to the touch.
    • Measure out the width of your face mask.
  2. Cloth Face Mask Nose Bridge Replacement: шаг 2, изображение 1 из 2 Cloth Face Mask Nose Bridge Replacement: шаг 2, изображение 2 из 2
    • Using a pen or pencil, mark the insertion point for the pipe cleaners.
    • A fabric pencil would be better suited for markings as it can be easily washed off.
  3. Cloth Face Mask Nose Bridge Replacement: шаг 3, изображение 1 из 1
    • Seam rip where the elastic portion is. If there is no elastic present, then seam rip along the top portion of the mask.
    • Caution: Be mindful of where you place your fingers as it is possible to accidentally jab yourself with the seam ripper.
    • Consider using a thimble for protection.
  4. Cloth Face Mask Nose Bridge Replacement: шаг 4, изображение 1 из 2 Cloth Face Mask Nose Bridge Replacement: шаг 4, изображение 2 из 2
    • Cut a 4” strip of pipe cleaner.
    • Use caution when cutting pipe cleaners with scissors.
  5. Cloth Face Mask Nose Bridge Replacement: шаг 5, изображение 1 из 1
    • Position the pipe cleaner where the markings are and fold the fabric over.
    • You may also use this as an opportunity to test out the positioning of the pipe cleaners before sewing the hem.
  6. Cloth Face Mask Nose Bridge Replacement: шаг 6, изображение 1 из 1
    • Sew around the pipe cleaner using desired stitch.
    • A basic running stitch is recommended for ease.
    • Try on the mask to ensure the fit is right. Bend the pipe cleaners to best suit your facial frame.
Финишная черта
Еще один человек закончил это руководство.
Kayla Vargas
Участник с: 02/23/21
157 Репутация
1 руководство автора
Команду
Texas Tech, Team S3-G15, Cowan Spring 2021 Участник Texas Tech, Team S3-G15, Cowan Spring 2021
TTU-COWAN-S21S3G15
1 член
Автор 3 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 729
