Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Dell Inspiron 17R-5721 RAM Replacement
Thomas Griffin
Thomas Griffin и еще один участник
Последнее обновление July 26, 2019
1 минут
Очень просто
Ненаглядные фото
RAM, while integral to a computer’s processing power, is designed to be simple to fix. In practice, most computers (including the Inspiron 17R) feature a system of unplugging used RAM sticks and plugging new ones back in.
Выберете то, что вам нужно
Инструменты
  1. Dell Inspiron 17R-5721 RAM Replacement, Battery: шаг 1, изображение 1 из 1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 RAM Replacement: шаг 2, изображение 1 из 2 Dell Inspiron 17R-5721 RAM Replacement: шаг 2, изображение 2 из 2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 RAM Replacement, Access Panel: шаг 3, изображение 1 из 1
    • Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
    • These two captive screws will loosen but will not separate from the panel.
  4. Dell Inspiron 17R-5721 RAM Replacement: шаг 4, изображение 1 из 1
    • Using a spudger, pry into the gap in the plastic revealed by loosening the screws.
    • Lift off the access panel.
  5. Dell Inspiron 17R-5721 RAM Replacement, RAM: шаг 5, изображение 1 из 1
    • Using your fingers, separate the metal tabs located on the left and right of each stick of RAM by pulling them apart from each other.
  6. Dell Inspiron 17R-5721 RAM Replacement: шаг 6, изображение 1 из 1
    • Pull each RAM stick out of the machine, separating each piece from its respective slot.
Заключение
Thomas Griffin
Участник с: 03/21/19
915 Репутация
Автор 9 руководств
Команду
UMass Dartmouth, Team S2-G6, Bailey Spring 2019 Участник UMass Dartmouth, Team S2-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S2G6
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 18
За всё время: 236
