Dell Latitude 7420 Back Case Replacement
Введение
Перейти к шагу 1This guide will lead you through removing the back cover of the Dell Latitude 7420, so that the internal components can be accessed.
Before starting, please ensure the device is turned off and disconnected from any adaptors or charging cables.
Likewise, use an anti-static band or mat when opening computers or handling components.
Выберете то, что вам нужно
Инструменты
Показать больше…
Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
Еще один человек закончил это руководство.
