Garmin Nuvi 200 Display Replacement
Введение
Перейти к шагу 1Opening the Nuvi and replacing a broken/damaged display.
Выберете то, что вам нужно
Peel off the sticker from the bottom of the device to reveal two screws.
Insert a plastic opening tool in the gap between the front and rear casing.
Carefully work the tool around the gap, separating the two halves of the case.
Apply pressure to the tabs holding the screen in place with the plastic opening tool
4 человек успешно провели ремонт по этому руководству.
