Google Pixel 7 Earpiece Speaker Replacement
Выберете то, что вам нужно
  1. Google Pixel 7 Earpiece Speaker Replacement, Safety precautions: шаг 1, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Safety precautions: шаг 1, изображение 2 из 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 7 Earpiece Speaker Replacement, Screen removal information: шаг 2, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Screen removal information: шаг 2, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Screen removal information: шаг 2, изображение 3 из 3
    • The screen of the Google Pixel 7 is held in place by plastic clips and adhesive.
    • During the removal procedure, make sure to insert your opening picks in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. In case your opening pick gets blocked during the screen removal procedure it means you inserted your pick too deep underneath the screen.
  3. Google Pixel 7 Earpiece Speaker Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. Google Pixel 7 Earpiece Speaker Replacement: шаг 4, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement: шаг 4, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. Google Pixel 7 Earpiece Speaker Replacement: шаг 5, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement: шаг 5, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement: шаг 5, изображение 3 из 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  6. Google Pixel 7 Earpiece Speaker Replacement, Loosen the display adhesive: шаг 6, изображение 1 из 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
  7. Google Pixel 7 Earpiece Speaker Replacement, Insert an opening pick: шаг 7, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Insert an opening pick: шаг 7, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Insert an opening pick: шаг 7, изображение 3 из 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
  8. Google Pixel 7 Earpiece Speaker Replacement, Prevent damage to your phone: шаг 8, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Prevent damage to your phone: шаг 8, изображение 2 из 2
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  9. Google Pixel 7 Earpiece Speaker Replacement, Slice the bottom edge adhesive: шаг 9, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Slice the bottom edge adhesive: шаг 9, изображение 2 из 2
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  10. Google Pixel 7 Earpiece Speaker Replacement: шаг 10, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement: шаг 10, изображение 2 из 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  11. Google Pixel 7 Earpiece Speaker Replacement, Release the left clips: шаг 11, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Release the left clips: шаг 11, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Release the left clips: шаг 11, изображение 3 из 3
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  12. Google Pixel 7 Earpiece Speaker Replacement, Slice the top edge adhesive: шаг 12, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Slice the top edge adhesive: шаг 12, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Slice the top edge adhesive: шаг 12, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  13. Google Pixel 7 Earpiece Speaker Replacement, Release the right clips: шаг 13, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Release the right clips: шаг 13, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Release the right clips: шаг 13, изображение 3 из 3
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
  14. Google Pixel 7 Earpiece Speaker Replacement, Open up the phone assembly: шаг 14, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Open up the phone assembly: шаг 14, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Open up the phone assembly: шаг 14, изображение 3 из 3
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame before continuing.
  15. Google Pixel 7 Earpiece Speaker Replacement, Release the display cable bracket: шаг 15, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Release the display cable bracket: шаг 15, изображение 2 из 2
    Купить
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
  16. Google Pixel 7 Earpiece Speaker Replacement, Remove the display cable bracket: шаг 16, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Remove the display cable bracket: шаг 16, изображение 2 из 2
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the cameras.
  17. Google Pixel 7 Earpiece Speaker Replacement, Disconnect the display cable: шаг 17, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Disconnect the display cable: шаг 17, изображение 2 из 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Google Pixel 7 Earpiece Speaker Replacement, Separate the screen: шаг 18, изображение 1 из 1
    • Separate the screen from the phone.
    • During reassembly:
    • Check that all screws are tightened and there are no loose parts.
    • Reconnect the screen and test your phone to make sure it works. Power it back down and continue reassembly.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  19. Google Pixel 7 Earpiece Speaker Replacement, Remove the black silicone pad: шаг 19, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Remove the black silicone pad: шаг 19, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Remove the black silicone pad: шаг 19, изображение 3 из 3
    Купить
    • Take care not to puncture or bend the battery with your tool in the following steps—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use a pair of tweezers to peel the black silicone pad off the battery and midframe.
  20. Google Pixel 7 Earpiece Speaker Replacement, Peel off the upper graphite foil: шаг 20, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Peel off the upper graphite foil: шаг 20, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Peel off the upper graphite foil: шаг 20, изображение 3 из 3
    • Use a pair of tweezers to carefully peel the upper graphite foil off the battery and midframe.
    • If you're having a hard time peeling off the foil, apply a heated iOpener to the foil for two minutes to loosen its adhesive.
  21. Google Pixel 7 Earpiece Speaker Replacement, Peel off the lower graphite foil: шаг 21, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Peel off the lower graphite foil: шаг 21, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Peel off the lower graphite foil: шаг 21, изображение 3 из 3
    Купить
    • Use a pair of tweezers to carefully peel the lower graphite foil off the battery and midframe.
  22. Google Pixel 7 Earpiece Speaker Replacement, Unfasten the loudspeaker screws: шаг 22, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Unfasten the loudspeaker screws: шаг 22, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the three 5.1 mm-long screws securing the loudspeaker.
  23. Google Pixel 7 Earpiece Speaker Replacement, Remove the loudspeaker: шаг 23, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Remove the loudspeaker: шаг 23, изображение 2 из 2
    • Use a pair of tweezers to lift the loudspeaker out of its recess and remove it.
  24. Google Pixel 7 Earpiece Speaker Replacement, Unfasten the midframe screws: шаг 24, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Unfasten the midframe screws: шаг 24, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the nine 5.1 mm-long screws securing the midframe.
  25. Google Pixel 7 Earpiece Speaker Replacement, Remove the midframe: шаг 25, изображение 1 из 3 Google Pixel 7 Earpiece Speaker Replacement, Remove the midframe: шаг 25, изображение 2 из 3 Google Pixel 7 Earpiece Speaker Replacement, Remove the midframe: шаг 25, изображение 3 из 3
    Купить
    • Use a pair of tweezers to remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
  26. Google Pixel 7 Earpiece Speaker Replacement, Disconnect the battery cable: шаг 26, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Disconnect the battery cable: шаг 26, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  27. Google Pixel 7 Earpiece Speaker Replacement, Disconnect the front facing camera: шаг 27, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Disconnect the front facing camera: шаг 27, изображение 2 из 2
    • Use a spudger to disconnect the front facing camera cable by prying the connector straight up from its socket.
  28. Google Pixel 7 Earpiece Speaker Replacement, Remove the front facing camera: шаг 28, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Remove the front facing camera: шаг 28, изображение 2 из 2
    Купить
    • Use a pair of tweezers to lift the front facing camera out of its recess and remove it.
  29. Google Pixel 7 Earpiece Speaker Replacement, Unfasten the earpiece speaker screw: шаг 29, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Unfasten the earpiece speaker screw: шаг 29, изображение 2 из 2
    • Use a Torx T3 screwdriver to remove the 5.1 mm-long screw securing the earpiece speaker.
  30. Google Pixel 7 Earpiece Speaker Replacement, Pry up the earpiece speaker: шаг 30, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Pry up the earpiece speaker: шаг 30, изображение 2 из 2
    • Insert the pointed end of a spudger underneath the bottom edge of the earpiece speaker.
    • Pry upwards to loosen the earpiece speaker.
  31. Google Pixel 7 Earpiece Speaker Replacement, Remove the earpiece speaker: шаг 31, изображение 1 из 2 Google Pixel 7 Earpiece Speaker Replacement, Remove the earpiece speaker: шаг 31, изображение 2 из 2
    Купить
    • Use a pair of tweezers to remove the earpiece speaker.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 answers community for help.
Dominik Schnabelrauch
Участник с: 11/23/16
205 085 Репутация
Автор 682 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 430 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 11
За последние 30 дней: 48
За всё время: 1,130
