HP Compaq 6710b Heat Sink Replacement
Введение
Перейти к шагу 1You will need to take out the keyboard as a part of replacing the heat sink. Know the steps to Keyboard Replacement before starting on this.
Выберете то, что вам нужно
Инструменты
Показать больше…
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Flip over the laptop to the top side, and open the laptop.
Slide the locking tabs down using a blue plastic opening tool or your fingernail.
Pull up on both sides of the black locking tab of the connector.
The keyboard should now be free of the computer.
Put a finger under each side of the plastic lock on the ribbon cable and pull up.
Using a flathead screwdriver, get under each plastic hinge cover until they pop.
Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Using two fingers, open the prongs holding the RAM
Then slide the RAM out from the socket
Using a Phillips #1 screwdriver, unscrew the two 7mm screws on the top and bottom of the fan.
Using two fingers, pull out the fan power connector.
To take out the fan, lift the bottom of the fan and take it out at an angle.
Using the Phillips #1 screwdriver, unscrew the four screws on the copper plate.
9 человек успешно провели ремонт по этому руководству.
3 Комментариев
That was easy. Thanks man :)
Piece of cake ! Thanks. :)
