HP Compaq Presario CQ56-110US RAM Replacement
Введение
Перейти к шагу 1Use this guide to replace the RAM stick. If your computer freezes up momentarily while running several programs, this may be the guide for you.
Выберете то, что вам нужно
Инструменты
Ensure the laptop is unplugged and completely powered off. Loosen the three small screws using a #1 Phillips screwdriver.
Carefully pry the panel up using a plastic opening tool.
Pull the panel away from the laptop and set it off to the side.
2 человек успешно провели ремонт по этому руководству.
