Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
HP Elitebook Folio 9470m Battery Replacement
Kenneth Bowers
Kenneth Bowers и 9 другие участники
Последнее обновление January 10, 2025
10 - 20 минут
Легко
The HP EliteBook Folio 9470m is a popular ultrabook known for its sleek design, portability, and reliable performance. Released in 2013, it features a 14-inch display, an Intel Core i5 processor, and 4GB of RAM, making it a trusted choice for business and everyday use. However, like all laptops, its battery life may diminish over time, affecting the device's performance and portability. If your laptop has trouble holding a charge, shuts off without warning, or the battery has physically grown from age or use, it could be time to replace it. The laptop will feel like new again after the battery is changed, restoring its portability and dependability.
This guide walks you through the step-by-step process of replacing the battery in the HP EliteBook Folio 9470m. Whether you're experiencing shorter usage times or a completely unresponsive battery, this guide ensures a safe and effective replacement. By following these instructions, you can restore your laptop’s mobility, extend its lifespan, and maintain peak performance.
When replacing your battery, it is crucial to take safety precautions, especially with a swollen battery. Swollen batteries can leak, smoke, or even catch fire if handled incorrectly. To prepare for any potential hazards, keep a pail of sand nearby to extinguish a fire if one occurs. It is important to perform the repair in a cool and dry environment. However, if you are inside, be sure to have a plan to get out in case your battery starts to smoke or catch fire.
Additionally, before starting your repair keep the laptop shut off. To remove the possibility of an electrical discharge, disconnect the power adapter. These are things to keep in mind when you replace your battery as they are for your safety and to prevent any further damage to your laptop.
Выберете то, что вам нужно
Запчасти
  1. HP Elitebook Folio 9470m Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Slide the central latch, revealing the red under it, to unlock the battery.
    • The switch reveals red when unlocked and is locked when black.
    • While holding the latch, slide the battery away from the hinge to remove it.
  2. HP Elitebook Folio 9470m Battery Replacement: шаг 2, изображение 1 из 1
    • Battery is now removed and replacement can be done.
Заключение
10 человек успешно провели ремонт по этому руководству.
Kenneth Bowers
Участник с: 04/08/16
1 432 Репутация
Автор 7 руководств
Команду
UMass Dartmouth, Team S1-G1, Valliere Fall 2018 Участник UMass Dartmouth, Team S1-G1, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G1
4 членов
Автор 19 руководств
2 Комментариев
Nice, thanks!
Do these batteries need to calibrate, or need any sort of SMC reset"?
Connor Dougherty - Ответить
Battery :
REPLACE WITH HP SPARE 687945-001
CT.6CSEL08BJ4WDJW
Mtg 2013/07
Please assist . THANKS
mary graham - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 11
За последние 30 дней: 89
За всё время: 23,349
