HP Pavilion x2 10-n113dx Touch Pad Replacement
Введение
Перейти к шагу 1This guide will show how to replace a touch pad in the HP Pavilion x2 10-n113dx. This guide is moderate in difficulty as one must open up the back of the keyboard. It is important to have a heat pad available so that one can reassemble the gray bumper on the back of the keyboard. The replacement guide requires a Phillips #0 screwdriver and a magnetic board is helpful for keeping track of screws.
Выберете то, что вам нужно
Инструменты
Показать больше…
Инструмент, используемый на этом этапе:Tweezers$4.99
Loosen the adhesive under the gray plastic bar using a heat pad or a heat gun.
Remove the gray plastic bar after 5 minutes of light heat with tweezers by pulling up.
Remove the rubber stoppers at the top left and right with tweezers.
Remove the screws at the top and right with at Phillips #0 screwdriver.
These two screws have a diameter of 5.3 mm and a height of 4.3 mm.
Pry open the back case with a metal spudger.
Then pry open the back layer with the metal spudger.
Pop open the ribbon cable piece on the touch pad with the blue plastic spudger.
Remove the ribbon cable with tweezers by pulling it out.
Remove 4 screws with at Phillips #0 screwdriver. All 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
Lift the tape shown with orange boxes with tweezers.
Remove metal bar with a blue spudger.
Lift up the touch pad by the metal edge with a blue plastic spudger.
Remove the touch pad from the computer.
