Инструменты
Запчасти
Детали не указаны.
Find the battery lock latch on the top left corner.
Slide the latch to the right position.
Find the battery release latch on the top right corner.
Slide and hold the latch towards the left to cover the battery icon.
Carefully slide the battery outwards.
Turn the laptop upside down with the base of the laptop facing you.
Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
Press the eject button.
Hold and carefully slide the disc drive out of the laptop.
Using the Jimmy, create a separation between the keyboard and bottom panel.
Slide around the body of the panel until the separation is big enough for you to use .your fingers.
Separate the keyboard and bottom panel.
Using tweezers, disconnect the left speakers from the motherboard.
Remove the left and right speakers from the laptop.
Slide the wires connecting both speakers out from the black stoppers.
You can now replace the speakers.
