HTC One S Vibration Motor Replacement
Выберете то, что вам нужно
  1. HTC One S Vibration Motor Replacement, iOpener Heating: шаг 1, изображение 1 из 2 HTC One S Vibration Motor Replacement, iOpener Heating: шаг 1, изображение 2 из 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. HTC One S Vibration Motor Replacement: шаг 2, изображение 1 из 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. HTC One S Vibration Motor Replacement: шаг 3, изображение 1 из 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. HTC One S Vibration Motor Replacement, Alternate iOpener heating method: шаг 4, изображение 1 из 2 HTC One S Vibration Motor Replacement, Alternate iOpener heating method: шаг 4, изображение 2 из 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. HTC One S Vibration Motor Replacement, Rear Case: шаг 5, изображение 1 из 1
    • Handling it by the tag, place the heated iOpener across the bottom casing.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the casing.
  6. HTC One S Vibration Motor Replacement: шаг 6, изображение 1 из 3 HTC One S Vibration Motor Replacement: шаг 6, изображение 2 из 3 HTC One S Vibration Motor Replacement: шаг 6, изображение 3 из 3
    • Gently place an opening pick in the corner of the gap between the bottom casing and rear case.
    • Slide the opening pick along the side of the casing, prying it away from the adhesive as you go.
  7. HTC One S Vibration Motor Replacement: шаг 7, изображение 1 из 1
    • Use your fingers to pull the bottom casing off the rest of the phone.
  8. HTC One S Vibration Motor Replacement: шаг 8, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 8, изображение 2 из 2
    • Starting at the groove near the headphone jack, use a plastic opening tool to lift the top casing.
  9. HTC One S Vibration Motor Replacement: шаг 9, изображение 1 из 1
    • Use your fingers to pull the top casing off of the rest of the phone.
  10. HTC One S Vibration Motor Replacement: шаг 10, изображение 1 из 1
    • Remove the following screws holding the rear case to the rest of the phone:
    • Two 3.15 mm Phillips #00 screws
    • One 4.15 Torx T5 screw
    • One 4 mm Torx T5 screw
  11. HTC One S Vibration Motor Replacement: шаг 11, изображение 1 из 3 HTC One S Vibration Motor Replacement: шаг 11, изображение 2 из 3 HTC One S Vibration Motor Replacement: шаг 11, изображение 3 из 3
    • Place your fingers on either side of the phone and gently push up on the rear case.
    • It is important to start from the bottom of the phone because the rear case wraps around the front of the phone at the top which makes it impossible to start prying from there.
  12. HTC One S Vibration Motor Replacement: шаг 12, изображение 1 из 1
    • Pull the rear case away from the rest of the phone with your hands.
  13. HTC One S Vibration Motor Replacement, Battery: шаг 13, изображение 1 из 2 HTC One S Vibration Motor Replacement, Battery: шаг 13, изображение 2 из 2
    • Using the pointed end of a spudger, lift the battery cable and release the connector.
  14. HTC One S Vibration Motor Replacement: шаг 14, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 14, изображение 2 из 2
    • Switching to the flat end of the spudger, work your way underneath the battery and peel it away from the adhesive.
  15. HTC One S Vibration Motor Replacement: шаг 15, изображение 1 из 1
    • Remove the battery from the phone.
  16. HTC One S Vibration Motor Replacement, Motherboard: шаг 16, изображение 1 из 1
    • Remove the three 3.15mm Phillips #00 screws from the turquoise case.
  17. HTC One S Vibration Motor Replacement: шаг 17, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 17, изображение 2 из 2
    • Using a plastic opening tool, lift the turquoise case from the end near the headphone jack.
  18. HTC One S Vibration Motor Replacement: шаг 18, изображение 1 из 1
    • Remove the turquoise cover from the phone.
  19. HTC One S Vibration Motor Replacement: шаг 19, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 19, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • A camera filter is now free to move, so remove it using tweezers.
  20. HTC One S Vibration Motor Replacement: шаг 20, изображение 1 из 3 HTC One S Vibration Motor Replacement: шаг 20, изображение 2 из 3 HTC One S Vibration Motor Replacement: шаг 20, изображение 3 из 3
    • Use tweezers to lift the yellow polyimide tape that covers the ZIF connectors.
  21. HTC One S Vibration Motor Replacement: шаг 21, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 21, изображение 2 из 2
    • Use the pointed end of a spudger to lift the white tab on the largest ZIF connector opposite the USB connector.
  22. HTC One S Vibration Motor Replacement: шаг 22, изображение 1 из 3 HTC One S Vibration Motor Replacement: шаг 22, изображение 2 из 3 HTC One S Vibration Motor Replacement: шаг 22, изображение 3 из 3
    • Use the pointed edge of a spudger to work the ZIF cable out of its connector.
    • To do this, you may have to slowly work both sides until the whole cable is released.
  23. HTC One S Vibration Motor Replacement: шаг 23, изображение 1 из 1
    • Repeat the procedure from steps 19 and 20 to remove the cables from the remaining ZIF connectors.
  24. HTC One S Vibration Motor Replacement: шаг 24, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 24, изображение 2 из 2
    • Using the pointed end of the spudger, pop the antenna cable from its connector on the motherboard.
  25. HTC One S Vibration Motor Replacement: шаг 25, изображение 1 из 1
    • Remove the 3.15 mm Phillips #00 screw from the motherboard.
  26. HTC One S Vibration Motor Replacement: шаг 26, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 26, изображение 2 из 2
    • Remove the motherboard from the rest of the phone.
  27. HTC One S Vibration Motor Replacement, Vibration Motor: шаг 27, изображение 1 из 1
    • Remove the plastic casing from the phone assembly.
    • If you have difficulty removing the casing, use the plastic opening tool to gently pry it off.
  28. HTC One S Vibration Motor Replacement: шаг 28, изображение 1 из 2 HTC One S Vibration Motor Replacement: шаг 28, изображение 2 из 2
    • Using the nylon spudger, remove the circuit board from the phone.
    • Use a metal spudger only as a last resort because it can damage the phone.
  29. HTC One S Vibration Motor Replacement: шаг 29, изображение 1 из 1
    • The component denoted in the red box is the vibration motor. Remove the component by desoldering the surface-mount joints.
Заключение
Adam Redmond
Участник с: 05/16/17
535 Репутация
Автор 5 руководств
Команда
IUPUI, Team S4-G3, Harley Spring 2017 Участник IUPUI, Team S4-G3, Harley Spring 2017
IUPUI-HARLEY-S17S4G3
3 членов
Автор 5 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 53
За всё время: 484
