How to Fix Your Cosplay Rabbit Ears
Введение
Перейти к шагу 1For this repair guide, I will be explaining the steps of how to fix your cosplay rabbit ears. This will make them be more sturdy, last longer, and look much more canon than some straight out of the package.
Выберете то, что вам нужно
Инструменты
Показать больше…
Rip the ears off of the headband.
Set the headband aside for now.
Cut a small hole into the middle backside of the ear, vertically, to remove the wired structure.
Feel around on the inside of the ear until you find the black wire.
Pull out the wire.
Straighten the wire completely.
Double the wire by bending it in half.
Bend one end a couple of times over, as seen in the pictures. This end will be the bottom base of the ear.
Add the wire back into the fabric ear, with the thicker end at the bottom of the ear. Make sure it is centered.
Thread your needle and do a simple stitch along the cut to sew up the hole from the wire.
When sewing down the wire, make sure that the wire is completely centered.
Sew a simple stitch along and down the wire, looping the needle over and under it.
Measure out a small piece of white fabric.
Cut out two strips of this measurement.
Wrap the fabric around one side of the headband, relatively tight.
Sew along the headband, as seen in the pictures. You should be able to slide the fabric off of the headband afterward.
Spread the two sides of the fabric strip out and place it on the base of the ear.
Sew each side down securely.
Slip the headband back into the fabric on both ears to make sure it is stable.
Your ears and now finished! They should stick up perfectly and be able to bend in different directions.
Еще один человек закончил это руководство.
