Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
How to Replace a Jeans Zipper with Buttons
Luis Caraballo Ortiz
Luis Caraballo Ortiz и еще один участник
Последнее обновление June 15, 2022
20 - 40 минут
Легко
Пропущенные шаги
Have you ever put on a pair of jeans and when you try to zip them up it breaks? Broken zippers are a common struggle that most people suffer daily because of the quality of the product or just because of the years of use. When a zipper breaks, this does not mean the jeans are not wearable anymore. Instead, it can be a great opportunity to add some buttons and give them a second life.
In this guide, you will be able to remove a broken zipper and add new non-sewing buttons without the need for expensive machinery or knowledge. In just 20 minutes, you will have a new pair of jeans ready to wear!
  1. How to Replace a Jeans Zipper with Buttons, Zipper: шаг 1, изображение 1 из 3 How to Replace a Jeans Zipper with Buttons, Zipper: шаг 1, изображение 2 из 3 How to Replace a Jeans Zipper with Buttons, Zipper: шаг 1, изображение 3 из 3
    • Open the broken zipper and identify the stitches.
    • Take the seam ripper and insert it under the last stitch seen.
    • Remove the stitches of the zipper and when most are removed, cut the rest of the zipper with fabric scissors.
    • Make sure to remove at least one half of the zipper.
  2. How to Replace a Jeans Zipper with Buttons: шаг 2, изображение 1 из 2 How to Replace a Jeans Zipper with Buttons: шаг 2, изображение 2 из 2
    • Insert the buttons tack to the right fly of the jeans.
    • Insert 2 or 3 button tacks, depending on the length of the fly.
    • Add textile glue to the pointed part of the tacks.
    • Adding glue to the tacks helps secure the buttons and avoids damage caused by the washing machine and daily use.
  3. How to Replace a Jeans Zipper with Buttons: шаг 3, изображение 1 из 1
    • While the textile glue is fresh, insert the buttons into the tacks and make sure they are secure.
    • You will notice the buttons are secure after you hear a clicking noise when pressing the buttons to the tacks.
  4. How to Replace a Jeans Zipper with Buttons: шаг 4, изображение 1 из 1
    • Cut three holes using the pointed part of the fabric scissor on the left fly of the jeans that correspond with the buttons on the right.
    • Make sure to open the fabric scissor and use only one blade.
    • Alternatively if you have access to a sewing machine, follow this guide to create the button holes.
  5. How to Replace a Jeans Zipper with Buttons: шаг 5, изображение 1 из 1
    • Using a needle and some thread, stitch the edges of the button holes to finish them.
  6. How to Replace a Jeans Zipper with Buttons: шаг 6, изображение 1 из 1
    • Make sure the buttons are secure, that they fit the holes, and that they open and close easily.
Заключение
At the end of the guide, you will have a pair of jeans that close with a set of buttons instead of a zipper.
Участник с: 03/18/22
133 Репутация
1 руководство автора
Команду
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 24
За последние 30 дней: 87
За всё время: 4,676
