How to Use the FixHub Web Console
    1. How to Use the FixHub Web Console, Connect your power station: шаг 1, изображение 1 из 2 How to Use the FixHub Web Console, Connect your power station: шаг 1, изображение 2 из 2
      • To use the FixHub Web Console, you need a browser with Web Serial enabled. We recommend Brave, Chrome, Edge, or Opera as they include this functionality enabled by default.
      • Firefox (and its derivatives) and Safari don't support Web Serial at this time.
      • Plug the Portable Power Station into your computer, making sure the cable is connected to the power station's rear port (the side opposite the screen).
      • Ensure your cable is capable of data transfer. Otherwise, you won't be able to use the web console.
      • Navigate to iFixit.com/FixHub/console
      Спросите у FixBot
      Добавить комментарий
    2. How to Use the FixHub Web Console: шаг 2, изображение 1 из 3 How to Use the FixHub Web Console: шаг 2, изображение 2 из 3 How to Use the FixHub Web Console: шаг 2, изображение 3 из 3
      • Click Connect my device.
      • Select your Portable Power Station from the pop-up window asking you to connect a serial port.
      • If your power station is completely drained, it may not show up. Skip to this step to boot into the bootloader.
      • Click Connect.
      Спросите у FixBot
    3. How to Use the FixHub Web Console, FixHub Web Console layout: шаг 3, изображение 1 из 2 How to Use the FixHub Web Console, FixHub Web Console layout: шаг 3, изображение 2 из 2
      • Once the FixHub Web Console opens, you'll see information and settings for your power station:
      • USB 1 shows info about the device connected to the power station's front left USB-C port.
      • USB 2 shows info about the device connected to the power station's front right USB-C port.
      • Battery shows the battery percentage in real time.
      • Serial number shows the serial number of the power station.
      • Version shows the firmware version and updates for the power station.
      Спросите у FixBot
    4. How to Use the FixHub Web Console, Firmware update: шаг 4, изображение 1 из 3 How to Use the FixHub Web Console, Firmware update: шаг 4, изображение 2 из 3 How to Use the FixHub Web Console, Firmware update: шаг 4, изображение 3 из 3
      • Before using the FixHub Web Console, ensure your firmware is up to date.
      • Select the Version box.
      • Click Update now and wait for the firmware update to complete. Don't disconnect your power station or close the window during the firmware update.
      • Once your power station updates successfully, be sure to update your soldering iron firmware to the same version.
      • If something goes wrong, you can downgrade your firmware by repeating these steps and clicking Pick a specific firmware version.
      Спросите у FixBot
    5. How to Use the FixHub Web Console, Firmware update using the bootloader: шаг 5, изображение 1 из 3 How to Use the FixHub Web Console, Firmware update using the bootloader: шаг 5, изображение 2 из 3 How to Use the FixHub Web Console, Firmware update using the bootloader: шаг 5, изображение 3 из 3
      • Follow this step to update a drained power station's firmware using the bootloader.
      • Unplug the power station from the computer.
      • Press and hold the adjustment knob.
      • Plug the power station back into to the computer, then release the adjustment knob.
      • The web console will show that the device has failed to start up.
      • Use the web console to manually update the firmware.
      Спросите у FixBot
Заключение
That's it!
Still need help? Ask our Answers community, or try some basic troubleshooting.
20 человек успешно провели ремонт по этому руководству.
Nick Schultz
Участник с: 03/24/24
59 266 Репутация
Автор 318 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 45 628 руководств
8 Комментарии к руководству
Can you update the app or website to display the latest firmware release information for this device? When I plug in my hub, it only shows the current firmware version on the device but doesn't indicate if it's the latest. Unlike other options, I can't click on the box for more details. Additionally, I couldn't find any information on your website about the current firmware version or its release notes.
john - Ответить Поделиться
The web console page is: https://www.ifixit.com/fixhub/console
This is where you can browse through the current and prior firmware versions. However, I don't believe the packaged firmware (at least with CI/CD) is currently open-source at the time of writing. Yet you can see what is currently available here on GitHub: https://github.com/ifixit/fixhub (The commands here work if you're able to access the FixHub with either minicomp on Linux or PuTTY on Windows; you can determine which TTY device the FixHub is assigned to with the help of the FixHub web console, which reliably picks out the correct low-level serial device name for the FixHub.)
Tai Lam - Ответить Поделиться
Settings tab is missing in the FixHub page for the Ifix-it portable power station. I am unable to reset battery health Calibration data for the PPS so i can perform initial battery calibration. is this a glitch? any suggestions?
Hector A - Ответить Поделиться
Same the settings tab is missing for me with no option to reset battery health calibration data after updating the firmware on the power station.
Slittcer - Ответить Поделиться
il manque le boutons settings, il y a un autre moyen de recalibrer la batterie ?
Alexandre - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 15
За последние 7 дней: 93
За последние 30 дней: 525
За всё время: 7,065
