Введение
This guide will help you install the dual hard drive kit, and can be used to add either a regular hard drive or SSD. This procedure does not require you to permanently remove or disable your optical drive.
Выберете то, что вам нужно
Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
Remove the access door from your iMac.
Use your fingers or the tip of a spudger to slide the black plastic RAM tray pull tab out of the RAM slot.
Bonjour, j’ai arraché la languette. Conséquence, elle est inutilisable et je ne peux pas retirer la barrette. Comment faire autrement ? Est-ce que cet outil peut être utile ?
Pull the black plastic tab away from the iMac to eject the RAM chip from its socket.
Use your fingers to slide the RAM chip out of its socket.
None. 4mb ram is too old to fit into any computer manufactured after like 1998.
@Brett
I suggest that you learn your unit symbols before you try to appear clever:
4mb == 4 milli bits
4MB == 4 mega bytes
nowsc was obviously meaning 4GB not 4MB, try not to be a dick.
Just for the records :
4 millibits are 0,000000004 MB
There was never any RAM in mb and the question states MB and nobody except you is talking of millibits.
You are also a dick if you try to spread “your knowledge” nobody has asked for
Take care to note which way out the RAM comes - there is a notch in each RAM and it is not centered, therefore either the notch will be on the left or to the right (depending on which way up you have your iMac). This will make it easier to replace the RAM without damaging anything.
If damaged the notch inside one pair of RAM slots, is it fixable ?
its not that hard to say that you can add up to 4GB sticks, bringing a total to 16GB
Инструмент, используемый на этом этапе:Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
You can easily lift the glass panel off the magnets with only your fingernails (or something thin like a credit card or a guitar pick). No need to buy suction cups you will only use once.
Yes, you don't need the specific suction cups to remove the display cover - it's held on by magnets, and if you start at the center by the iSight you can work out to the edges and remove it. I had an iPhone screen suction cup around and it helped with balancing the screen when you pull it out fully, but by no ways is it required.
Thanks!!! Worked excellently.
I used a plunger (clean first ;-) to get the screen off, and http://exirion.net/ssdfanctrl/ for fan control.
Then, i did not take out the whole display and left it in the hinges on the bottom side and held it up with two small cardboard boxes. Easy enough to disconnect the hdd then.
I replaced with an ssd, put that into a ssd enclosure. Had to drill an extra hole in it to fasten the pins that hold it in place.
Used Carbon Copy Cloner to make an image from the old hdd, with the sad connected via usb. Checked it of it booted via System Preferences > Startup Disk. It worked so the took the imac apart and replaced the disk. Booted, everything was working as always, only faster!
I'm replacing my optical drive too. what exactly needs to be plugged into the SSD? I don't have the kit - as I am not sure one is required if I buy something like this: http://www.amazon.com/gp/product/B0056OB...
Can you please advise? Can I do it with this piece, or do I need to get the entire bracket kit?
My display data cable forks, with a smaller section going up near the camera board. Where it forks, it is attached to the aluminum plate that attaches around the cpu board. I haven't seen any images that look similar, and I'm stumped at how to remove this second section of the cable. 2010 i7 build to order
Agree with the other comments here. Despite buying suction cups, not sure they were necessary as the screen removed very easily. A sat nav suction cup would do the job fine.
I can confirm that it is possible to remove the front glass using fingernails rather than suction cups. It isn’t easy, but if you try you should be able to pry off the glass.
I did this twice: once at the beginning of the procedure and once again at the end, when I realized that a big pice of lint was trapped under the glass.
Don’t use suction cups. totally unnecessary. screen pops off with fingernails.
The reason for caution about suction cups tends to be making sure you don’t apply uneven pressure on the edges of the glass and crack it in the process of removal. I do agree however that some pretty small suction cups would do fine. These suction cups can be had at your local princess auto (Harbor freight) for a few bucks and are useful elsewhere as well. if you use your fingernails or other items just try and do it evenly :)
A great first step that minimizes that first gust of dust migration when the glass is lifted is to clean the glass, sides *and the back* before lifting the glass, and then lift SLOWLY. Most of that dust is already trapped inside and pulled up as the screen lifts, but with care you can keep it there (or gently vacuum out with a micro vac…).
Thanks for the instructions. Before doing this the first time, suggest to everyone, read through at least twice. This is the easiest step, as you’ll soon see. As for removing the glass, USE suction cups, either the ones the sell here, or others. DON’T skimp. Also wear gloves when handling the glass. Don’t take chances.
Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
you should do this mac up, because, for me, one of the suction cup failed, and the glass fall into the lcd screen. Now there is a big hole in it...
do you still have this panel?
Reassembly: After powering on and running for a few minutes, found a large whitish patch on the screen. Persists after powerdown.
Turned out to be condensation, though it didn't look like it - more like fine white powder rubbed in. Humidity is very high this time of the year. Fix: start airconditioner in a room, leave it running a while, take iMac in, prise open the glass again. Condensation vanishes instantly. Keep it out for a ~15 minutes running infinite loops to get iMac nicely heated up and fans running. Snap glass back.
I used a Swiffer dry cloth to get all the dust off the screen while just blowing with my mouth at a steep angle. I know I didn't get every speck, but the screen looks perfect once assembled and lit again. Removing the glass from the screen is pretty easy if you need to re-clean it.
I used a microfiber cloth instead, which worked well. The same type as yo use to clean eye glasses, but in a larger form factor.
Daniel -
The Swiffer idea worked great! I just brush it over the LCD and glass panel lightly, and all dust particles are gone quickly. The screen after boot up looked beautiful. Thanks!
dtsai2 -
I didn't crack the screen, but it popped out of the shims and then popped back in, as if the glass edge is magnetic or has steel in it to connect to magnets. Be careful with this step — it is pretty nerve-wracking, but doable!
You need a big clean surface free, or at least 2 or more free surfaces because the iMac, the glass and the LCD display are quite bulky. You'll also probably need space for a tablet or a laptop to read this guide while you are working. And don't forget room to work on the optical unit and for the tools you are going to use. I covered a large table with a double layer of bubble wrap. In my opinion it's better to put the glass face down to limit powder sticking on the internal surface.
Thanks good advice! I was wondering exactly about the working space issue!
I am doing this repair now. After successfully lifting off the glass panel (yay!), dust blew out of the lower open edge. So I sprayed a can of air around edges. But a poof of the “air” condensated on the LCD. Does anyone know if I can clean the LCD same as how the glass is cleaned (damp cloth with equal parts white distilled vinegar/distilled water) and if not then how?
Hi Amy,
To clean the LCD panel, I would suggest using a clean microfiber cloth and rubbing alcohol. Distilled water can be used, but avoid regular water, which contains minerals. Make sure the microfiber cloth is absolutely clean and has no hard particles sticking on the surface, which will scratch your LCD when you wipe it.
Wet the surface with some alcohol and gently wipe with the microfiber cloth. Wipe in one direction.
I find that the LCD is not as fragile as we all think. they are very much like any LCD on a tv or monitor. There is no extra glass on the front of a monitor. Not the 23 HP Pro Displays I have anyway. I know this because I punctured one moving my video wall. so I took it apart to know how its put together. I will say, there are several 'lens’ like sheets and a reflective (silver} sheets that are the same size as the panel. and a 1/8”piece of acrylic, all behind the LCD panel. Take care with them and clean as you would your monitor.
My suggestion is to stand the iMac up after the panel is secured back into the body of the iMac and clean while its vertical. took me 3 attempts before I realized that while laying flat the surface is large and collects dust with mind blowing speed.
If the LCD glass is badly cracked and broken you need to be extra careful removing as the sharp shard of broken glass can scratch/harm the underlying screen as they may “fall in or onto” the screen below.
I found that strategically putting sheets of 8x11 paper(s) under the sharpest, largest broken sections help protect the underlying screen. A vacuum was also helpful removing some of the small glass shards.
Be advised: I did a perfect replacement of the hard drive, temperature sensor to the SSD, LCD screwed in, glass cleaned. I went to put back the final glass, I set the bottom edge in place and as I slowly moved to have the magnets take hold, they pulled the screen out of my gingerly held fingers, and smacked into place……cracking the glass! Ugh! So, on this last step, hold tight as you put the glass back in slowly. It will cost you about 40-50 bucks for a new glass (mine is on it’s way).
Yikes... that sucks. thanks for sharing this information. I took everyone's advice and removed and placed this back very very carefully.
Don't trust the suction cups after you remove the screen cover. Used both hands to hold this piece carefully!
As far as the last point of step 2 goes, I would add to the parts list a can of compressed air to get rid of all the dust on the screen frame and the interior body once the lcd is off). When the magnets clip back in dust will shower down onto the lcd and glass if you do not clean the frame well. It will not matter how much you clean the LCD and inside of the glass panel.
Remove the eight T10 Torx screws securing the LCD to the outer case.
All screws were exactly the same for me.
There were only eight screws holding the lcd in place on the sides 4X4
Carefully lay the iMac stand-side down on a flat surface.
Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
Raise and hold the display high enough to access the cables.
I followed the procedure in the Apple Technician Guide and it was a lot easier. Stand the iMac upright on the stand (as per normal operation) and then carefully tilt the top of the unit towards you while holding the top of the LCD. The LCD just falls forward into you hands. It is also then easier to disconnect the cables.
This procedure can be VERY dangerous. Why? Because there is the possibility of a gravity disaster if you lose control of the screen and it falls before you disconnect the interface cables. I know. It happened to me. After studying the Apple directions I came to the conclusion that I would need both hands on releasing a couple go the cables and decided to tape off the screen in the open position - which I did very carefully and securely. What I did not account for was the tape not adhering. Needless to say when it came loose the screen fell and ruined the connector sockets (and my computer). This could also happen just trying to hold the screen with one hand while spudging the connectors apart with the other as well. SO. LAY THE iMAC DOWN! DO **N O T** GIVE GRAVITY THE CHANCE TO RUIN YOUR DAY like it did mine!
It’s the fourth time I follow this guide, power supply, gpu and dual hd operations carried successfully and I feel and works munch more relaxed with the iMac laying horizontal on his back. I’m lifting the screen with two hooks at the same time, no torsion on the frame makes munch easier to lift it.
Then I put in the corners two pieces (two short pencils do the job) of about 3 1/2”, 9 cm, to maintain lifted the screen while disconnecting the ribbons.
Now the GPU I’ve changed in 2017 has lasted less than three years and here I am to change it again.
After disconnecting the first ribbon you can lift the screen more than 5”, enough to access the other ribbons easily.
As others have posted here, Do NOT let gravity assist you. Put the iMac on it’s back when doing the remaining steps. Also, use some type of hook to assist you in terms of lifting out the display assembly. Expect some resistance, since it does weigh a few pounds. Also, as you’ll see in the next step, you can help yourself by using something to brace it at each corner to keep it lifted. Some have suggested chop sticks, bic pens, etc. Use something approx. 4-5” in length. That will give enough clearance, and not put strain on the cables.
To spare a paperclip, I had better to use a good needlenose plier, catch the iron frame just near the corner, and hook up.
Used plastic spudgers as levers, one pointed to start in the corner, then two flat, working across gently. When I got to the middle and pried a bit, the top lifted all the way across, allowing access to the cable in the next step. I decided against doing this with the unit standing vertically.
Disconnect the vertical sync cable in the upper left corner of the screen. Use the tip of a spudger to push on the connector's side tabs and gently walk it out of its socket.
After disconnecting the VSync cable, I was able to keep the screen wedged apart by 8" which gave me enough working room to extract and replaced the hard drive without having to remove Step 6 - 8. This resulted in a faster change out of the hard drive.
Amen brother! These are great guides, but could be improved with tips to simplify some processes. I just did the same as you, and it was quick and easy, with less chance to damage cable connections.
thank you for the tip. faster swap-out and less risky. cheers
Eric -
Totally agree. I did exactly the same. Less chance for mistakes having to do and then undo steps 6-8 and faster and easier. The whole process was shockingly simple. Sad I waited so long.
JLTX -
After disconnecting the first cable, I was getting ready to disconnect the second cable when I realized that the amount of opening necessary to get to the second cable, is also sufficient to get to the hard drive, so why go the extra steps. I used a wedge I had close by to very carefully keep the screen up, to enable removing the hard drive with both hands. If you are replacing the hard drive, skip to Step 11.
Bret -
I did this and supported the LCD with two chopsticks. Jumped right to step 11. Power supply replaced; no fuss. Great suggestion. Thanks.
I did this and I agree. I don’t know about the alternative (doing steps 6-8) because this is my first time doing this but it was definitely quick and “safer” than disconnecting a bunch of cables (the Vsync cable alone was scary bc it feels so fragile). Only downside is you have to replace the HDD while holding a heavy panel with one hand. That being said, there was more than enough room to get around.
This quicker method also came in handy when I had to open it up again right after closing it because I forgot to install a piece 😂🤦🏻♂️
adam -
Once I put the tip of a very small flat-head screwdriver on the other side of the spudger tip, the connector popped out.
This is the answer :-) After 10 mins of faffing about on my own I read the manual (this) and this tip took less than 1 second to get the connector out. Thank you so much, me fellow workers were getting annoyed at my swearing.
simonf -
I've managed to break off the fitting in step 6 trying to remove the screen, would anyone know the part to buy or how to fix this?
It is very hard to detach the connector with the spudger. I tried forcing the connector out with the spudger by pushing on one side and then the other repeatedly. After several times it finally came out. A tool would be useful for this; there must be special plyers for doing this. Fingernails on either side seems most obvious, but maybe there is a downside to this ?
Rocking it back and forth with some “outward” pressure on both sides was the key. This was the only connector in this upgrade that gave me a problem.
with some confidence and mechanical inclinations this is the only cable you need to disconnect to replace the hard drive. pointer finger on one side thumb the other, pull up.
Use either a spudger or a small flat head screwdriver to loosen the sides of the connector. Then use small needle nose pliers to disconnect the cable. It’s easier than trying to wedge your hand in there.
I broke the vsync cable removing it. Any tips on how to replace it? The wire is hair thin and I have trouble stripping even much bigger ones. I don't suppose iFixit sells a replacement?
First Thanks. Your parts and guides have (hopefully (still doing a restore)) shown me how to upgrade my HDD to SSD! I would warn extra caution on the 2 small sets of connectors with the bendy pins. Both the cases on mine were broken. Presumably when it went into Apple for a new Graphics card. I found it very difficult to line the pins up and had to straighten them several times before I could reconnect them. Probably due to the cases being broken and not helping with alignment.
Disconnect the LED backlight driver cable with your hand by pressing the tab down and sliding it towards the bottom of the display.
Do step 7 first. The cable is much shorter and more fragile, you'll have more space to remove the other cables if that one is removed first. On my mac, the cable in step 7 was glued down and had to be freed up before I could pull the connecter out of its socket.
Just skip step 6,7,8 and 9 with this powerful tools: two bic pen holding the frame.
Look at pictures: https://www.dropbox.com/sh/5jwam38drgcov...
I also used two pens to hold the display panel up and I had to detach only the vertical sync cable from the display on step 5. Much easier!
Hello Fabio, can you please re-up the picture? It doesnt seem to be online anymore :(
Thanx a bunch!
Good idea! I used two chopsticks as they are longer. Placed them near the corner and use one of the T10 screw's hole in the side of LCD panel to prop it up. Fit perfectly and very sturdy. This gave me plenty of space to work with the replacement.
dtsai2 -
I don’t get how smite six can be skipped—we’re these steps renumbered at some point? How could you even lift the display if you didn’t remove the screws in step 6?
Pull the black tab straight up to disconnect the latch on the display data cable ZIF connector.
Continue to pull the black tab up toward the top of the device, to detach the display data cable.
me too. All went well expect replace this flat cable which is tricky almost when my view is low and I've got big finger. I broke the cable end connector to motherboard but I don't know if I damaged the connector on motherboard. I'm waiting from Apple service for diagnostic.
I would suggest on the guide to add a step to explain how sensitive is to replace this cable. iMac should lay on the back and it should have some stuff to maintain the motherboard elevated in order to insert the display port flat cable to the motherboard on a less stressful way.
This image is 100% inaccurate. My mac has a different style connector that needed to be pinched on each side to release the cable.
Its not 100% incorrect for him as this was his connector. It was only incorrect for you.
asthomas -
Its accurate for my Mid 2011 3.4ghz iMac so it could be different for different iMac model years.
Chris -
How do you get the ZIF connector back in? Some screenshot or instruction would be very helpful. I cannot get mine back in.
This is really difficult, but essentially it slides in - with no discernible click. A *slight* tug on the lever lets you know its connected. Horrible thing.
Use the ‘bic pen’ trick and you don’t have to remove this for most things but I had to go ‘back in’ to remove the super drive. I then used the tip next down and removed this connector at the screen also and put this end back in first with no screen in the way.
I found the best way for me to reinstall the ZIF cable in was to lay LCD panel on its face and gently peel the black tape on upper part of lcd to expose and remove the connector there. At this point the ribbon cable is free and you can insert the hard to align connector to the board. Set LCD into imac and connect the small push connector next to the ribbon cable on board. It was easier to see and then reconnect the cable to the upper portion of LCD and tape it back over. Reinstall other connectors etc. This way worked best on my 27" iMac as it was much easier.
The is a great tip
I had to replace the cable due to damage from trying to reinsert it at the logic board and I found it best to re-attach it exactly the way that thewiseone71 describes it above. If you disconnect the part at the top with the tape around it, this goes much easier and there is less of a chance of damaging the port on the logic board where it attaches at the other end. I think some photos of this port, and the way this cable goes back in would be a great addition to this tutorial. Replacing this cable would also make a great tutorial.
So like everyone else, I managed to screw this up. Do you remember where you picked up the replacement, or what I should look for specifically when looking for a new one? I looked on amazon, but the label on the one I found doesn’t match what is on mine.
Thanks!
What would be really helpful to this guide, and this image is the closest I can find in the sequence, is a quick summary of exactly where the diagnostic LEDs are on this model (and what they mean, although the latter is easily googleable). I only mention this as I believe my PSU is goosed as no LEDs are illuminated anywhere, however I can only find references to 2009 and 2010 of the similar MYs which evidently have diagnostic LEDs in a different place, hidden under tape, and I suspect numbered differently. So I can't be 100% certain!
I can see why some people are breaking the connector in step 7. You do initially pull the tab up, perpendicular to the logic board, which unlatches the connector, but then it is finally disconnected by then pulling the tab toward the top of the computer, parallel to the face of the logic board. I found it easier, after disconnecting the sync cable in step 5, to then prop up the bottom of the LCD, in order to better reach the ZIF connector, the LED backlight driver cable and the display power cable.
I messed this bit up too. It says “pull up”. As the iMac laid flat on the table, I pulled towards the ceiling, bending the pins. It should say “pull towards the top of the machine” or something.
I managed to straighten them out with a tweezer. Looked like a couple of pins were missing at the end, but it looks ok.
Now I have to figure out what I have done to the temperature controller, the fans blow on full speed all the time here. :)
Like others that have commented, this cable is a major PITA. I used both a headlamp to illuminate the area, and the iPhone’s Magnifier app to zoom in. The connector on the motherboard is flat, low profile and characterized by a thin narrow slot. The key to removing the cable is to slide the cable out, (after flipping that bar forward). Re-attaching the cable is the same - carefully sliding the cable into that slot, while keeping that bar pulled backward, until the cable was in place.
For me, this was the most difficult part of the hard drive replacement. I spent more time on this than anything else.
Use the tip of a spudger to disconnect the display power cable next to the display data cable.
need more description than “disconnect” here. It took my awhile to figure out that it’s was a “back toward” connector.
Thanks John, would you give a short suggestion on how to help other users to remove such a “back toward” connector to make it clearer?
Angel -
I broke 1 of the pins on the logic board side when reconnect. Now my iMac have no display. Not sure how to fix it.
Need better description here with close-up photos to avoid accident like mine.
Cheat on this one. Loosen the tape on the back of the display. That gives you more slack on the cable. The connector is pretty standard.
I could not reconnect this cable. How to put back?
Jagat, it’s easier if you lift the other side of the display.
Carefully pull the display toward the top edge of your iMac and lift it out of the iMac case.
When I opened up my iMac, I was surprised at how dusty it was inside. You might want to have a vacuum cleaner handy to vacuum up the dust inside the case. Be careful not to vacuum up the screws, though!
do not use a vacuum cleaner, it has ESD!!!!!
find a vacuum that is for computer use that has no ESD
FYI...I did this fix, upgraded my mid 2011 27" to a Samsung 850 EVO SSD Hard Drive. Everything went great except for two parts...
1. When I started up with my install media I got a three beep error and I could not install. I ended up using the CRTL-R at startup and did a network install that downloads an image of the original OS that comes with the system and allows you to install with the correct file.
2. Hard drive fan was spinning at full speed the whole time. This was annoying to say the least. Another person on this thread commented on this and said that you had to buy a $30 piece of software to fix it, I actually found another one that is free and works quite well (http://exirion.net/ssdfanctrl/).
Just completed the upgrade and put a 1TB SSD in. I have used this software and seems to do a good job. http://www.crystalidea.com/macs-fan-cont...
adrianh -
There seems to be a missing step here. All the while one is removing the cables from their sockets it is supposed that the screen which is quite heavy is suspended in mid air… no, you are holding it up with one hand while doing everything single handed while in all honesty it would be nice to have both hands if for nothing else to steady your movements. So. Lets add a step. Lets figure out a solution and use some kind of prop until the screen is removable.
ESD = Electrostatic Discharge
Lay the display face down on a flat, soft surface.
If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Use the flat end of a spudger to pull the optical drive data cable out of the optical drive.
Use the tip of a spudger to pull the optical drive thermal sensor connector out of its socket.
Slightly lift the left edge of the optical drive and then pull it to the side to release the centering pins.
There are two small plastic positioning pin holes on the right of the optical drive. When you replace the drive, make sure to align the pins with the holes as you slide the drive back into place.
Use the flat end of a spudger to pull the optical drive fan connector out of its socket.
Use the tip of a spudger to pull the SD board data cable connector out of its socket.
Use the flat end of a spudger to push the I/O cable connector out of its socket.
Use the flat end of the spudger to pull the microphone cable connector free of its socket.
Release the right and left speaker connectors from their sockets using the flat end of a spudger.
Locate the AirPort card at the top center of the logic board and just below the hard drive.
Use the flat end of a spudger to gently pry each of the antenna cables off their sockets.
Do not disconnect the wires. Way over complicated. Follow the OWC instructions instead: unscrew the single Torx T6 screw and then wiggle the airport card off of its socket completely. No need to remember markings or add warnings about sensitive cables. Very easy step if done as described.
If you do it this way check the optical connections afterwards. They are easily disturbed and in my case 2 of them came adrift. Fortunately I spotted this before re-installing the screen.
I tried to unscrew the torx T6, but for some reason the screwdriver did not fit the screw. I had a T6. The screw is acting like the head is stripped already. Oh well, disconnected the tiny cables just fine.
the markings were different with my imac 27” 2,7 GHz : ch0 - 2 marks, ch1- 1 mark - ch2 - no mark.
Use the flat edge of a spudger to push the camera/Bluetooth/ambient light sensor connector out of its socket.
I have got the ssd installed as my second drive using the dual drive kit. However, after reassembling everything, the CPU fan is running at full speed. Apple Hardware Test shows a failure for the error code TA0P, which points to a failure of ambient temperature sensor/connector. I have reassembled this machine 3 times now, with and without the ssd installation components and the problem is not going away.
Does anyone know a fix for this? I do not have warranty on this machine (2011 iMac. 27'') to get the logic board replaced for free. However, I'm willing to get the sensor connector checked by a technician if that would fix it.
Requesting help! :-(
I have posted a detailed question at Faulty CPU/ODD sensors or fans after Dual Drive Kit Upgrade
Does the additional sata cable has one male and a female end or else? Could someone post a link to the right cable on amazon for example?
Today I have completed the installation of a Crucial MX100 254GB successfully. With help of the guides from ifixit and OWC it was not that difficult.
However, when I booted my iMac the fans started raving.
I reset SMC and PRAM several times. Opened the machine again to check connectors and cables. Same story as above.
Everything looked fine, but the fans kept spinning at max. Seems like a booby- trap, it happens again and again.
I would prefer things to work different but I now use Macs Fan Control to keep the peace.
I hope this riddle will be solved one day.
Release the hard drive fan connector from its socket by pushing on its tabs using the flat end of a spudger.
Anyone know what the empty socket between steps 25 and 26 is for?
It’s a factory diagnostic port. You’ll find most Mac’s have such a port sometimes its not wired in followup generations of the logic board.
Dan -
Push the thermal sensor connector out of its socket with the flat end of a spudger.
Use the flat edge of a spudger to release the CPU fan cable
its mentioned here:
Use the flat end of the spudger to push the ambient temperature sensor connector out of its socket.
Use the flat edge of a spudger to pull the power button connector free of its socket.
Broke power button connector on logic board
Trying to find the name of this connector, any help would be greatly appreciated
Thanks!
Found it — the part is 51021-0200
Locate the IR sensor located behind the black Apple logo.
Detach the IR sensor by pulling it straight up and out from the case.
I accidentally broke the plug/cable when trying to reconnect..Does anyone know where I can find a replacement?
The cable side or logic board side?
Dan -
Remove the eight T10 Torx screws securing the logic board and heat sink assembly to the iMac case.
The screws are of various lengths, so note carefully which order you remove them so as to replace them correctly. Especially note that of the three screws surrounding the right fan, the one closest to the optical drive is slightly longer that the other two (which are the same length).
Les vis ont des tailles différentes, pensez à repérer où va telle et telle vis.
Ne pas oublier la huitième vis tout en haut dans le coin
Don’t forget the (8th) screw at the top right of the case holding down the heatsink.
Simultaneously lift and rotate the logic board and heat sink assembly away from the iMac case until you can easily access the back side of the logic board.
On the back of the MLB, below the graphics card socket, are 4 connections. While freeing the board, & as you tilt and lift it, gently rotate the whole assembly a bit less than 90˚ to the right, i.e. clockwise. This provides the slack needed to reach behind the board and disconnect them.
Should you want to completely remove the MLB (in order to repair a dead Graphics Card, for example) be sure to note the orientation of these 4 rear cables. During re-assembly, replace these in the same orientation. Otherwise there will be a tangle and you will experience problems getting the MLB back in place.
I was able to change the graphic card without unplugging the 4 cables behind the motherboard. It was a bit difficult because I only have 2 hands and had to hold the MB while unscrewing the GC but it’s possible. Thanks a lot for the trick about rotating the MB. It was useful.
Vor der Entfernung des Logic-Boards ist es ratsam, die von den Halterungen entfernten Kabel am Rahmen und am Lüfter mit Klebeband festzukleben. Es besteht sonst die Gefahr, dass beim Einsetzen des Logic_Boards einzelne Kabel unter dem Logic-Board eingeklemmt oder verdeckt werden.
Locate the secondary SATA socket, next to the primary SATA socket.
Plug in the included SATA data/power cable.
Route the new SATA cable through the indentation that the primary SATA cable goes through and into the optical drive bay.
Set the logic board back into place, being careful not to catch, cover, or pinch any cables.
To secure your new drive in your iMac, you will need to place high strength double-sided tape at the four corners on the side of the drive with the SATA connectors.
Peel the backing off one side of the double sided tape.
Press the exposed adhesive side of the double sided tape to the corner of the SSD.
Repeat the above process for the remaining 3 corners.
Connect both the SATA data and SATA power connectors to their respective sockets on the SSD.
Peel the backing off of the double sided tape.
Carefully set the SSD into the iMac optical bay as close to the lower left corner as possible.
Once you are happy with the SSD's placement, firmly press down along its edges to ensure full adhesion.
Mac upgrades website do an optical bay conversion kit that means you do not need to remove the board and the whole install takes about 30mins. Also, fan issues- if you carefully remove the thermal sensor from the optical drive (its only stuck down with a little glue on the drives surface ) you are removing and then stick it onto the surface of the new hard drive the fans work perfectly.
This guide says that “When re-installing the optical drive, the SATA cable will be sandwiched between the foam padding and the optical drive.” There’s not much foam padding to sandwich in the iMac that I have open.
@Craig, not sure if you ever got your answer but you should see the SSD as soon as you pop off the display. To others out there, with a HDD iMac, you can also add a second (SSD) drive to the right of your HDD, behind the frame for the graphics card (GPU). I’ve done this on a 27” with the smaller GPU and it fit very well.
Placing SSD behind optical drive inside iMac 2011 - is a really bad idea! This is the only air channel for a video card’s heatsink. And it’s already partially occupied by the optical drive. There is a lot of place in the central area, where original HDD was placed. And if you are really into upgrading that gorgeous classic, the best thing you can do - throw HDD out. This is also will give you a lot of new free space inside. And also will free up another SATA slot, so you will be able to install a pair of SSD, while keeping optical drive (or 3 SDD w/o optical).
Thats not true, the air flow is from the bottom to the top not from the side.
Dan -
The previous comment is actually true. I installed for the 2nd time a SSD behind the optical drive (first one died after 10y of use) and didn’t take care to put it to the side. The airflow got somehow blocked by the SSD and 3 days later my graphics card is dead. Be careful when you install SSD to make sure it’s well fixed to one side.
I’ve put in a ton of SSD’s none have failed because of being placed behind the optical drive and the GPU in this series often fails! With or without a SSD placed behind the optical drive. My own 2011 27” system has gone through four GPU boards and it doesn’t have the SSD mounted behind the optical drive. The HDD and the GPU each have dedicated fans.
The root issue is we push the graphics too hard playing heavy games and/or doing image or video work on this series. Apple (AMD) didn’t realize the speed apps would progress using more power than they anticipated during the design process.
Dan -
To reassemble your device, follow these instructions in reverse order from Step 27.
355 участников успешно повторили данное руководство.
71 Комментариев
Excellent guide. Thank you!
I got through everything, turned on the iMac, got the start up gong, and ... nothing. Screen stayed black and the fans started blowing like crazy, indicating failure of Apple Hardware Test. All my attempts to remedy (zap PRAM, reset SMC) failed. Uh oh.
Opened the machine back up, took out the LCD, and re-seated all four connections from display panel to logic board. Crossed my fingers and put it back together. This time, the displayed turned on, the Apple logo appeared, system booted up, and the new SSD appeared on the desktop. Yay!
The connectors from the LCD are delicate. It's tricky to seat them properly without damaging them, but don't close it up without a positive click on each one.
The upgrade has been fantastic so far. SanDisk 120GB SSD. Dramatic speed improvement. Well worth all the surgery on the machine.
in step 22 you can see the wifi cables are not connected anymore. but there is no step that shows you should disconnect them
+1 Unfortunately mine has been broken (CH1 cable is out from the UFL connector). Unfortunately I do not now how to repair it.
It would be important to add this step in order to protect others falling into the same issue.
PeterZ -
i followed this guide to the T. used a 240gig Corsair GS and after it gets far along the boot process the fans blow at max speed! i took the monitor off again to make sure i had all the connections in the right place. there was one i was missing... the ambient temp lol. but i plugged it back in and still fans blow full blast :( gonna keep messing with it to see if i can figure it out :)
Hi, I have successfully installed a 1TB Seagate Hybrid hard drive and everything seems fine, except the fans are blowing at full speed constantly. Is this because the heat sensor for the optical drive is missing now? Has anyone got a solution?
Thank you
It's because the standard Seagate drives contain a proprietary thermal sensor. you will have to purchase HDD Fan Control to get it to stop. It's the only solution short of shorting out the thermal sensors (dangerous).
Install the trial and you'll see.
I wouldn't recommend using HDDFanControl, because its not really a long term fix... I used it for a while, but it frustrated me that the fans didn't idle until the machine was fully booted, so if you need to do anything in single user mode, safe mode or even a boot camp or separate OSX boot up, you cannot use it. In the 2011 range, i'd recommend using this as a long term hardware solution
All sorted!! I didn't realise I could install the optical drive back over the new hard drive, the fan keeps both very cool. Once I connected the optical drive & thermal sensor the fans calmed down to 1100 rpm. If you don't want to install the optical drive just take off the thermal sensor and connect it to the new hard drive and the logic board. Another thing I have learned in this experience is you need the optical drive in to install Windows (bootcamp) or you get a partitioning error at install. It is a safety feature Apple incorporated. Hope this helps others!! Thanks again for the replies
Andy -
OWC has a pretty good vid of this mod, including lots of important cautions which are absent from this guide. OWCmacsales is the channel name. I will be using all available material as this mod is high on the pucker-power scale.
Why has double sided tape been used in this guide instead of the SSD brackets that are designed to be screw mounted under the optical drive? there are 3 screw mounts allocated to the mounting of the SSD. With the heat that is generated by the iMac machines, i'd be worried about it losing its bond and falling down, especially using tape bought from Boots instead of high strength industrial tape...
We found that Apple removed the SSD brackets / screw holes in later units of the same model, and we wanted a universal solution that would help everyone add a dual drive to their iMac.
The hack worked perfectly, thank you ifixit team & support!
There was a slight amount of compression when re-setting the logic board, but it doesn't appear to have stressed or pinched anything (yet). It certainly goes in a bit awkwardly. It does suffer a bit of a twist while man-handling it in & out. A bit unnerving.
The first set of suction cups had a defect and one wouldn't hold, & ifixit sales got one in the mail lickety split. +5 stars, ifixit sales!
A few suggestions managing airborne dust:
— do the hack on a windless, foggy day
— see the OWC video for how to handle & temporarily store the glass & LCD
— use a small camel-hair brush to drag dust mites to the edge of the LCD or glass during re-assembly.
Not sure what I'll do about internal dust in a year or so . . .
I followed this guide successfully with the kit from ifixit and everything works very nicely. However, I somehow lost the sd card cable, which is not a big deal since my mom doesn't use the sd card slot. I'll put it back next year when I replace the hdd.
If you are planning on doing this, I have a couple of suggestions for you:
* count the cables you disconnect
* before putting the logic board back in, tape all the cables to the sides with some masking or electrical tape and count them again
* try not to touch the lcd, fingerprints are a pain to remove, don't touch the underside of the glass panel either, put it down suction cups down
The guide may look scary, but it's really not that bad.
Don't forget to install Trim Enabler or Chameleon SSD Optimizer for TRIM
Trim Enabler: http://www.groths.org/software/trimenabl...
Chameleon SSD Optimizer: http://chameleon.alessandroboschini.it/
In the guide step 32 I see that connector is L-shaped, but in the kit picture it is not L-shaped. How important is to have L-shaped connector? Is there a place for a straight one?
I did this upgrade this week and was successful. I definitely don't recommend attempting this if you've never done a PC build, studied PC repair, or don't have steady hands. It helps a lot if you have a spare laptop playing the OWC video and playing/pausing it as you do each step. Also, I wore latex gloves to help prevent fingerprints from getting on the LCD.
A tip for migrating to the SSD: install a new OS instead of cloning. After I installed the SSD, I could not get into the Recovery due to some error, which using Recovery is an essential step to migrate OS X from the HDD to the SSD. A way around this issue is downloading Mavericks via the Mac App Store and do a new OS X install. From there, install OS X on your new SSD, then use the Migration Assistant to move everything to your new drive, which it does really well for you. Then, you can toggle Startup Disk in System Preferences (in case you aren't booting using the SSD).
Oh, and don't forget to manually enable TRIM on your new SSD.
I installed the ssd and now I have the cpu fan running at full blast. it seems to start about 10 seconds after the iMac starts. I've go far as to undo and redo all of the steps TWICE. I've also detached the ssd and the cpu fan still runs at full blast. I've also tried the software solution and nothing works? It seems to be running at 3800 constantly. Any ideas? Please HELP!
Hi Andrew,
did you get that solved ????
I have the same problem now :-(
Thanks
Uwe
Great guide.
Today I installed a Samsung EVO 840 250GB SSD behind the optical drive and swapped out the original 1TB Seagate HDD for a 2TB one. Works great.
This is not a very difficult thing to do. Just keep calm.
The hardest thing was to put the motherboard back in place...
My tips:
1. Read the steps a couple of times.
2. Have someone helping you holding the panel up while disconnecting those 4 cables.
3. Use a spudger and your fingernails to remove the cables. (spudger on one side/tab, fingernail on the other tab, or if possible just fingernails.
4. Mark every cable you disconnect (for example "pwr btw"). This make the rewiring a piece of cake.
5. Don't clean the "glass" with anything other than very hot water. I held it on the edges and held it in the shower. Any glass polisher or so will give you a headache. (I have tried to get it really clean several time before) Now its as good as new.
6. Yes. The fans WILL spin, but I use HDD fan control. Now it's super-SILENT ;)
There are too many steps in this guide that are unnecessary. Reading the comments, it seems like people are making mistakes and having problems. Follow the online video at OWC and it is an easier process, although still advanced. When you buy an SSD kit, it includes the proper length SATA cable and thermal double-sided tape. Someone commented about an SSD bracket behind the optical drive. Apple did not include the SSD bracket unless you bought the Mac build-to-order directly from Apple with their SSD installed. That is why thermal double-sided tape is used to secure the drive behind the optical drive. It won't go anywhere because the drive rests on the top of the optical bracket when you press it against the back panel, and the optical drive is re-installed in front of the SSD holding it in place. I did this upgrade about a year ago using a Samsung 840 EVO 1TB SSD and it is awesome.
Done it in a hour and a half, great guide! "Hardest" part was replacing the mother board :s.
If you want to save money, you can buy your tools on eBay, 1st prices 3$ Torx T10, 3$ opening tools set, 10$ sata power cable, guitar pick instead of suction cups
Well. First I tried to source all of the parts in Canada, thinking it would take forever to get here from ifixit. I wasted more time doing that than anything else. It took 3 days for the HD, cables and repair kit to get here.
I have worked on, in and around computer my whole career so I was eager to take this on. The tear down and installation were straight forward (have the guide handy) but getting the main board seated in the right spot was frustrating to say the least. It wouldn't go back in, it took me over 30 minutes of careful attempts . It is all in there now and I am extremely happy with the performance and the storage!
You will need a fan controller software.
Anyone know of a GOOD 'how to' on using the terminal to make this a functional Fusion Drive? I can't get mine to unmount to wipe then merge it, been trying for 2 days
I used this guide when I did a similar upgrade to my 21.5" iMac. Worked like a charm. http://blog.macsales.com/15617-creating-...
zachary -
Nice, and thank you very much for the guide !
Now I have a very strange behaviour here.
Since I installed the "Dual Hard Drive Kit" (the second cable basically) the FIRST SATA connector doesn't work any longer !
(I installed my second drive, wondered why it was not recognised, though it might even be broken 'till I switched the two disks and found out now my new disk was recognised but the old one was no longer visible).
My main objective was to switch my old (slow !) 1TB disk for a new 2TB with 4GB SSD cache.
So that's done.
But any idea why the primary SATA connector would no longer work ?
Is there anything like "primary" and "slave" switch (sadly known in the PC world ...) I should worry about ?
TIA for you help, and best regards,
Roger
After installation of this setup my ODD Fans are going crazy. I did run a AHT and the error told me there is something wrong with the ODD temp sensor. So i tried replacing the temp sensor with a new one. I also tried removing the SSD and get back to the default state, also nothing.
Any tips or tricks on how to resolve this?
just installed a SSD, but now I can't hear any sound from the OS. when I start the MAC, I get the usual "Bong", though. What mistake did I do? should I be looking for?
can't you just use the optical drive sata connectors to connect the new HD? just wondering cos i've seen other solutions which seem to attach the hd to a mount and then re-plug the optical sata cable back to that mount and looks MUCH MUCH MUCH easier.
i'm still to do this i've just ordered the kit, but if i would have seen the other kit before i would have ordered that one instead i think :/
So many of us are having issues with the fans running at high speeds but no response from ifixit. Frustrating that they don't pay attention to their users
Hi, is it possible to add two SSDs and totally 3 disks?
Thermal sensor to fix fans...
Hello! I looked all of the instructions and read all the comments, but did not understand why so many complex actions with removing the motherboard? Why no one uses optibay as here: Installing iMac Intel 21.5" EMC 2389 Dual Drive ???
EVERYONE WITH FAN ISSUES: After searching for days only finding conflicting explanations for my fan issues, this site explains it all:
https://thisdoesnotcompute.org/2012/12/3...
I installed the SSD as described below the optical drive, but the fans still went full blast. I thought this was only supposed to be happening if you replaced the original drive?
Well, at least it is now properly explained, and a solution exists.
UPDATE: I still had fan issues after the "shorting trick" described above. However, running Apple Hardware test I found that I had a ambient CPU temperature sensor error. THIS DID NOT SHOW UP AS AN ERROR USING FAN CONTROL SOFTWARE, all sensors reported OK. I t turns out that sensor sockets can very easily be installed reversed when reassembling. It was very easy to fix when the sensor was identified. If you have trouble running the Apple Hardware test, have a look at the sensor connections: The solid plastic side should be down.
I now have no fan issues with an SSD installed as secondary, keeping the original HDD intact to make a great fusion drive. The "shorting trick" is probably only necessary if you replace the drive with the SSD.
The morale is: RUN THE APPLE HARDWARE TEST, do not trust the sensor values reported by the fan control programs.
Booting with D or OPTION-D should start the hardware test. This did not work for me, so I googled to find instructions on bootable USB stick installation.
Stupendo tutorial molto esaustivo e ben illustrato. Complimenti.
ilario bignasci
I have a question about this. What is the procedure to make a 2nd SSD the boot drive instead of the original HDD? Do I need to swap SATA Cables or can this just be done during the OS X Install? Thanks!
Option key at boot lets you specify boot device (DVD or external drive or secondary drive), but otherwise - if you're already in macOS on the old drive, goto System Preferences and select Startup Disk. You get to pick and choose whenever you want!
Successfully completed, was not so difficult :)
Excellent guide, thank you very much. I have just followed it to replace the SSD in my iMac (added 3 years ago following the same guide) and I took the opportunity - while I was up to my elbows in iMac bits - to swap the CPU. Replaced the OEM Core i5-2500S with an i7-2600. So far, touch wood, everything is running just fine. Thank you again!
Addendum to my previous comment, because apparently there’s only a 5-minute edit window, grrr..
A couple of observations:
- Have a can of dry compressed air to hand. You’ll need it to blow dust off the exposed LCD panel (as the guide says, do NOT touch the panel… even wiping it with a cloth can leave a residue). Chances are there’ll be an accumulation of dust on the internal fans & heatsinks. Take the opportunity to give everything a good blast.
- Screwing the LCD back is perhaps the trickiest part, because there are strong magnets around the chassis frame (to hold the glass front panel). The screws will try to “snap” to the magnets rather than lining up. Care, patience, & a steady hand are required. A sleeved screwdriver would make this MUCH easier.
More points - wish I could have put these in one comment but there’s a length limit. I’m trying to be useful here!
- There are a LOT of small connectors (temp sensors, speakers, fans, etc etc). I suggest small labels to put on the cables as you remove them; easy to miss one as you put them back, or make a mistake.
- The screws that hold the mainboard in place are of different lengths. Make a note of which screw came from where, so you can put them back in the right place.
That gives me an idea - hey, iFixit, why don’t you make available life-size templates of device internals, so that someone following your guides can print out the template and use it as a place-mat to keep the screws while working? I.e. “this screw came from the corner of the mainboard, so I will temporarily store it on that location on the printed template”…?
Not a bad idea! Paper printouts have their limitations though—one good sneeze or gust of wind and everything gets messy fast. Printouts are also arguably a bit wasteful as people tend to use them once and then toss them out. If you haven’t yet, give the magnetic project mat a try—personally it’s my favorite tool for electronics repair, hands down. Congrats on a successful repair!
I use markers of different colors to mark the position of the connectors and screws.
Just paint the male and female of the connector with the same color and do the same with the heads of the screws and a paint point of the same color in the PCB.
alozano -
Complimenti, tutorial molto comprensibile ed esaustivo. Bravo
Upgrade done. It is hard to connect the lcd to the motherboard (step 10). The first time I didn’t do it well and when turn on the computer, the display doens’t show nothing and the vents run like crazy. I turn off, connect again the connector (step 10) and all run well! Five star to this guide.
I added a 500GB Samsung SSD and also replaced the i5 2500S with a i7 2600. It works like a breeze! Had some issues with the ram, causing beeps after reassembly, but fortunately that was solved when switching the ram sticks a bit. Now I have a very fast iMac and together with 20GB of ram, a nice machine to do development on. Hoping that newer iMacs will again be more serviceable, but for now I am happy with this one!
Successfully added a 1TB Samsung SSD in a little over an hour, cloned the old HD over and voila! This has breathed new life into my iMac and I couldn’t be happier.
ì have my imac with fans running at full speen now do you have any idea why it would do this after adding the ssd ?
Hi everyone, I have a problem installing SSD behind the optical drive. Under the DVD there are 4 screws that prevent me from positioning it as a guide. the only way is to insert SSDs horizontally and when I get back up the reader fails to take the DVDs and can't even reject them, most likely it goes wrong or is slightly compressed. How can I do?
Jack - Did you push the drive against the black vertical rail? The curvature of the back case on the right side will push the drive to far forward which will interfere with the optical drive. I also find the drive needs to be mounted vertically flat with the connectors either at the top or bottom.
Dan -
This is the wrong guide! Jump to this one for your 21.5” system Installing iMac Intel 21.5" EMC 2428 Dual Drive Kit. The adapter & its kit is the same iMac Intel 21.5" (Mid 2011) Dual Hard Drive Kit
Dan -
Just wondering why the 27” iMac kit isn’t interchangeable with the 21.5” kit?
Thanks.
The 21.5” version has discreet cables unlike the 27” version which has the exact same cables but has a heat shrink tube to hold the cables together. this is done to protect the cables from the higher heat and their placement.
Dan -
I finally solved my FANS BLOWING AT HIGHT SPEED problem (hardware solution, no software)
Running the Apple Hardware Test (booting with D key. If you are in an infinite loop, you need to be connected to your modem physically) send me the “4SNS/1/C0000008 : TAOP - - 124 “ error code, relative to the Ambiant thermal sensor.
It seems that it’s really easy to invert the ambiant thermal sensor as you replugged it into the socket (step 28 as you remount your mac).
As visible in the picture in step 28, the grey cable should be oriented to the bottom of your mac as the black one must be to the upper side.
Don’t use software solution because your mac is really downgrading performance (espicially GPU usage) in order to prevent burning component.
Thats not true! the air flow is from the boot to the up not to the side.
Dan -
Hallo, ich habe das genau so gemacht wie in der Anleitung. Aber wenn ich beide Festplatten angeschlossen habe ist der i mac 20” tot und macht gar nichts. Am alten Anschluß läuft die ssd oder die normale Festplatte und wenn ich sie am ssd Anschluß am Board abklemmen läuft die ssd oder die normale Festplatte auch.
Aber es darf nur eine angeschlossen sein.
Was habe ich falsch gemacht?
Gibt es einen Trick?
Vielen Dank
Andre
Translation: Hello, I did it exactly as in the instructions. But when I have connected both hard drives the i mac 20 ”is dead and does nothing. The ssd or normal hard disk runs on the old connection and when I disconnect it from the ssd connection on the board, the ssd or normal hard disk also runs. But only one may be connected. What have I done wrong? Is there any trick? Many thanks Andre
Dan -
Sie haben angegeben, dass Sie einen 20 "iMac haben. Ist das richtig? Wenn Sie diese Liste überprüfen, um Ihr System auszuwählen, iMac Intel 20"
You stated you have a 20" iMac is that correct? If it is review this listing to select your system iMac Intel 20"
Dan -
Excellent guide. Mission accomplished.
Por aqui deu tudo certo só usei um sofware para monitorar o cooler … o resto esta funcionando perfeitamente
Translation: Here everything worked out fine, I only used a software to monitor the cooler… the rest is working perfectly
Dan -
Does anyone on here know if I can externally fix my old hard drive to the my present Mac . My old computer screen just went black , and I need to get some information of my old hard drive ? Thanks liam … email. carasac@gmail.com
Yes, just get an external HDD case which can hold your drive and make sure the port connection if offers works with your new system. Many offer USB-A connections which then can via an adapter can connect to a USB-C port.
Dan -
I combined this guide with the hard drive (main) replacement (iFixit) and one from OWC to add another drive using their Data Doubler in place of the DVD drive. Net result is 3-1 TB SSDs in a 2011 27" iMac. Also upgraded RAM to 32 GB. Running Monterey 12.3.1 via OpenCore Legacy Patcher.
That was fun!
How does this work for a Mid-2011 iMac-27 that had the "fusion drive"? I have already "spilt" the SSD and HDD and replaced the HDD with a 4 TB HDD. I suspect the 256 "blade" SSD is getting "long in tooth" and would like to replace it with a higher capacity SSD.
The Fusion Drive is really only the base HD in size, the blade SSD is only a cache drive to speed up the file (data blocks) to load
The dual drive config is a bit different as both drives are accessed. The boot drive (blade SSD) as it’s the faster of the two I/O ports and the SATA data drive often the original HDD or some times replaced with a second SSD. As your data files don’t need the faster I/O.
Dan -
I am going to put a very important comment here. Before you start this process listen to the fans on your iMac do any of them sound obviously loud (think about how quiet your iMac used to sound as a reference) If you notice one or more of them sounding substantially loud compared to the others consider locating a replacement fan prior starting this process. After all if you are already “in the neighborhood” it is a shame to do all this work only to have to disassemble your imac a couple weeks later because you realize the fan is failing. I speak from my own personal learning experience of having to disassembly my iMac 3 weeks later because the HDD was failing and apparently the moving the fan around was just enough to push it to start really under performing.
Wizbang FL - Ответить
I’m not sure why it is necessary to remove the RAM. As far as I can tell, it can remain in place during this procedure.
gordonhamachi - Ответить
