JBL Go 4 Battery Replacement
Выберете то, что вам нужно
    1. JBL Go 4 Battery Replacement, Battery: шаг 1, изображение 1 из 3 JBL Go 4 Battery Replacement, Battery: шаг 1, изображение 2 из 3 JBL Go 4 Battery Replacement, Battery: шаг 1, изображение 3 из 3
      • Insert an opening tool into the seam in between the grille and chassis, in the top corner opposite the strap.
      • Slide the tool along the edge of the housing until the grille releases.
      • Remove the grille.
      • Be sure that the battery has been drained completely before attempting this replacement.
      Спросите у FixBot
      Добавить комментарий
    2. JBL Go 4 Battery Replacement: шаг 2, изображение 1 из 3 JBL Go 4 Battery Replacement: шаг 2, изображение 2 из 3 JBL Go 4 Battery Replacement: шаг 2, изображение 3 из 3
      • Insert an opening tool in the opposite corner, lifting carefully.
      • Slide the tool along the edge until the cover pops off.
      • Gently pull the housing up and to the side.
      • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
      Спросите у FixBot
    3. JBL Go 4 Battery Replacement: шаг 3, изображение 1 из 2 JBL Go 4 Battery Replacement: шаг 3, изображение 2 из 2
      • Find the connection between the motherboard and the battery cable as labeled.
      • Gently depress the plastic tabs and slowly wiggle the connector until it comes free.
      • Be incredibly gentle with this connector as any excessive force can damage the motherboard.
      Спросите у FixBot
    4. JBL Go 4 Battery Replacement: шаг 4, изображение 1 из 2 JBL Go 4 Battery Replacement: шаг 4, изображение 2 из 2
      • Insert an opening tool beneath the battery, on the side opposite to the battery cable.
      • Using a lever motion, pry the battery out slowly, sliding it further under to break the adhesive up.
      • It's important to note that the battery is held on with a small adhesive pad, so more force than should feel necessary will be needed.
      Спросите у FixBot
Заключение
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jackosn Caron
Участник с: 03/20/25
255 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 4-1, Konn Spring 2025 Участник UMass Dartmouth, Team 4-1, Konn Spring 2025
UMASSD-KONN-S25S4G1
4 членов
Автор 21 руководств
2 Комментарии к руководству
Great guide, thanks! Small point -
Typo - “Insert an opening into the seam”. I think you’re missing ‘tool’.
Alexander Dyas - Ответить Поделиться
Thanks for pointing that out, @alexanderdyas. We took care of the typo. In the future, feel free to go ahead and make the edit!
Connor Bassolino - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 33
За последние 30 дней: 140
За всё время: 1,591
