Lenovo Essential G570 Keyboard Replacement
Введение
Перейти к шагу 1Over time, the constant use of the keyboard keys may cause them to break down and become unresponsive. This guide demonstrates how to replace the keyboard on the Lenovo Essential G570 laptop.
Выберете то, что вам нужно
Инструменты
Turn off the laptop.
Disconnect the charging cable.
Turn the computer upside down.
Locate the two switches that lock the battery.
Push the right switch outwards to unlock the battery.
Push and hold the left switch outwards to unlock the battery.
Pull the battery away from the computer.
With the screws removed, insert the plastic opening tool into the groove located on the right side.
Begin to pry up, and the plate should lift up from the body of the laptop.
While lifting up, take the piece in one hand and pull up and to the right to fully remove the back plate.
Remove the two 9mm Phillips #0 screws.
Remove the single 5mm Phillips #0 screw.
Flip the computer over and open it.
Using the plastic opening tool, pry open the top of the keyboard.
Remove the keyboard by gently pulling the top of the keyboard loose, and then lifting the keyboard out.
While lifting the keyboard, push the black latch on the keyboard cable ZIF connector forward to unlock it.
Carefully pull away the ribbon cable to detach it from the motherboard.
4 человек успешно провели ремонт по этому руководству.
