Lenovo G40-30 Speaker Replacement
Введение
Перейти к шагу 1This replacement is moderately difficult and should only take fifteen to twenty minuets. You will need a JIS #0 screwdriver, tweezers, and a plastic opening tool. Before you start on the speakers make sure you take out the battery.
Выберете то, что вам нужно
At the top of the laptop you will see two switches, like in image one and two.
Pull the switches outwards with your thumb, towards the unlocked lock.
Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
The keyboard should only be connected by a ribbon on the underside of the keyboard.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use the tweezers to lift the black hinge on the ribbon connector.
Then pull the ribbon from the connector and remove the keyboard from the laptop.
After you have the screws out apply pressure with your thumb and slide the hard drive to the left.
When the hard drive is completely left gently pull up on the right corner.
Using the plastic opening tool split open the laptop on the ends. Starting from one side to the other.
These two are the speakers.
This is the connector.
Unscrew the two 4mm JIS #0 screws.
In order to remove the speakers you must first pull back the blue circuitry that covers the speakers.
Then, remove the left speaker by pulling it up and off the prongs holding it. Repeat this step for the right side
Next, use the tweezers to pull the connector out away from the screen.
Еще один человек закончил это руководство.
