Lenovo G50-70 Fan Replacement
Введение
Перейти к шагу 1The fan on a computer is important for cooling the parts that generate a lot of heat. If fan is not running properly, there is a risk of other parts overheating and causing damage to critical components. Most computers have thermal throttling; this means speeds will decrease when it starts to overheat to prevent from damage.
Выберете то, что вам нужно
Инструменты
Push the left switch (labeled 1) to the left to show red underneath. This will unlock battery.
Push the right switch (labeled 2) to the right. This will eject battery.
Remove the three 6mm Phillips #0 screws holding the back access panel on.
Slide the cover toward you to unlatch it.
The edge of the panel will slide away from the laptop so it can be lifted.
7 человек успешно провели ремонт по этому руководству.
