Lenovo G500S Touch Battery Replacement
Введение
Перейти к шагу 1If you find that your computer fails to hold a charge or isn’t turning on, it may be time to replace the battery. This simple guide will show you the steps to remove the battery from the device.
Flip your device over so that the back is facing you.
Using your fingers, push the tabs in opposite directions to eject the battery.
Remove the battery from the device.
