Lenovo Yoga 710-11ISK Motherboard Replacement
Введение
Перейти к шагу 1The Lenovo Yoga 710-11ISK’s motherboard is one of the most important components as it acts as a brain for all the internals. This guide shows how to disassemble the computer in order to access the motherboard and replace it.
Выберете то, что вам нужно
Инструменты
Показать больше…
Remove the eleven screws that attach the back panel using a T5 Torx screwdriver.
Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
Use a Phillips #000 screwdriver to remove the four screws securing the battery.
Hold the cable connector on both sides and gently pull it directly out of its port.
Lift the battery up and out.
Use a Phillips #000 screwdriver to remove the eight screws securing the motherboard, Wi-Fi card, and SSD card.
Unplug the Wi-Fi and SSD cards from the motherboard along with the attached wire harnesses.
