MacBook Air 13" Early 2015 Trackpad Replacement
Выберете то, что вам нужно
Видеообзор
    1. MacBook Air 13" Early 2015 Trackpad Replacement, Lower Case: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      P5 Pentalobe Screwdriver Retina MacBook Pro and Air
      $5.99
      • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
      • Two 9 mm screws
      • Eight 2.6 mm screws
      Спросите у FixBot
      Добавить комментарий
    2. MacBook Air 13" Early 2015 Trackpad Replacement: шаг 2, изображение 1 из 1
      • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
      Спросите у FixBot
    1. MacBook Air 13" Early 2015 Trackpad Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 13" Early 2015 Trackpad Replacement, Battery Connector: шаг 3, изображение 2 из 2
      • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
      • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
      • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
      Спросите у FixBot
    1. MacBook Air 13" Early 2015 Trackpad Replacement, Battery: шаг 4, изображение 1 из 1
      • Remove the following five screws securing the battery to the upper case:
      • Three 6.9 mm T5 Torx screws
      • Two 3.0 mm T5 Torx screws
      Спросите у FixBot
    2. MacBook Air 13" Early 2015 Trackpad Replacement: шаг 5, изображение 1 из 1
      • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
      • Lift the battery from its edge nearest the logic board and remove it from the upper case.
      • Your replacement battery may arrive with a plastic film lightly adhered to the top surface. Remove this film when you install the battery. However, if the film is glued on and is difficult to remove, you should leave the film in place.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Спросите у FixBot
    1. MacBook Air 13" Early 2015 Trackpad Replacement, Trackpad: шаг 6, изображение 1 из 3 MacBook Air 13" Early 2015 Trackpad Replacement, Trackpad: шаг 6, изображение 2 из 3 MacBook Air 13" Early 2015 Trackpad Replacement, Trackpad: шаг 6, изображение 3 из 3
      • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
      Спросите у FixBot
    2. MacBook Air 13" Early 2015 Trackpad Replacement: шаг 7, изображение 1 из 2 MacBook Air 13" Early 2015 Trackpad Replacement: шаг 7, изображение 2 из 2
      • While carefully lifting the keyboard ribbon cable with one hand, use the tip of a spudger or your fingernail to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
      • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the Air.
      Спросите у FixBot
    3. MacBook Air 13" Early 2015 Trackpad Replacement: шаг 8, изображение 1 из 1
      • Remove the following twelve screws:
      • Six 1.6 mm Phillips screws securing the trackpad to the upper case.
      • Six 1.6 mm Phillips screws securing the trackpad brackets to the trackpad.
      Спросите у FixBot
    4. MacBook Air 13" Early 2015 Trackpad Replacement: шаг 9, изображение 1 из 1
      • Remove the right and left trackpad brackets from the upper case.
      Спросите у FixBot
    5. MacBook Air 13" Early 2015 Trackpad Replacement: шаг 10, изображение 1 из 1
      • During reassembly, check the clicking action on the trackpad.
      • The 1.4 mm T5 Torx screw near the front edge of the case must be adjusted correctly.
      • If overtightened, the button will cease to click at a certain point. Adjust the set screw until the clicking side of the trackpad has minimal play.
      • It's not necessary to remove this screw in order to remove the trackpad.
      Спросите у FixBot
    6. MacBook Air 13" Early 2015 Trackpad Replacement: шаг 11, изображение 1 из 2 MacBook Air 13" Early 2015 Trackpad Replacement: шаг 11, изображение 2 из 2
      • Use the flat end of a spudger to carefully lift the edge of the trackpad closest to the keyboard from its recess in the upper case by lifting it away from the brackets attached to the upper case.
      • Remove the trackpad from the upper case.
      Спросите у FixBot
Заключение
40 человек успешно провели ремонт по этому руководству.
Sam Goldheart
Участник с: 10/18/12
477 818 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 44 111 руководств
11 Комментарии к руководству
Hi,
I have replaced the keyboard of my MacBook Air, now touchpad and keyboard stop work after login.
It does not works even in single mode nor with install drive.
Can anyone tell me why this happened?
PS. I also changed all the upper case with touch and keyboard and same issue.
It does work with external devices.
Claus - Ответить Поделиться
First step is to double check the keyboard and trackpad cables! See step 6 and step 7 in this guide!
Sam Goldheart - Ответить Поделиться
I am in a similar situation, I recently replaced the trackpad on my MacBook Air and I am having the same problem with the trackpad and keyboard working fine during login, but it stops working after boot.
Did you find a solution? Is there a way to fix this?
Joe Walker - Ответить Поделиться
Hi,
I replaced my touchpad of my macbook air 2013. Now The touchpad functions partly in the beginning. It moves nothing to bad in the beginning, but after 5 minutes it works well. I checked the cables, but they seem to be plugged in fine, especially if they seem to work after 5 minutes. What could this be?
P.S. I used the old brackets of the trackpad for the new one. I was wondering what the function was of the connection between the bracket and the small circuit board and if that could be the problem.
martijn breuls - Ответить Поделиться
Hello! I was able to remove the six screws securing the trackpad brackets to the trackpad. But the six screws securing the trackpad to the upper case are just stuck! No matter how much pressure I apply, they won’t give. Can someone help?
Chi A - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 27
За последние 30 дней: 142
За всё время: 57,449
