Введение
Use this guide to replace a damaged lower case.
Выберете то, что вам нужно
Видео обзор
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
14 участников успешно повторили данное руководство.
Один комментарий
Does anyone have experience replacing the feet? I see iFixit sells them (MacBook Air Plastic Feet) but it’s not clear what kind of glue to use (and that webpage doesn’t have a “comment” section where to ask such questions). Also Apple has a support page for the replacement of similar feet in MacbookPro (https://support.apple.com/en-us/HT202450) that seems to suggest that their own kit (which I can’t find for my laptop) came with glue.
