Введение
This serves as the starting point for every guide—you'll need a P5 Pentalobe screwdriver to remove the lower case and get into the device.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case.
Gently pull the lower case away from the upper case to remove it.
20 участников успешно повторили данное руководство.
Комментариев: 5
Nice………………..!
I’m trying to install my lower case back but it’s refusing to clip back in. Any way I can fix it?
