Введение
Use this guide to replace the camera board.
Выберете то, что вам нужно
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
Remove the lower case.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Use the tip of a spudger to push the small plastic cable retainer away from the camera cable socket for enough clearance to remove the camera cable.
Pull the camera cable toward the optical drive opening to disconnect it from the logic board.
Carefully pull the Bluetooth cable toward the fans to disconnect it from the Bluetooth board.
Use the flat end of a spudger to peel the thin plastic cover off the top and sides of the Bluetooth board housing. For late-2011 models check out the other picture because the connector location is in a totally different location.
Use the flat end of a spudger to pry the Bluetooth antenna connector up and off its socket on the Bluetooth board.
De-route the camera cable from the slot molded into the Bluetooth board housing.
Remove the two 7.1 mm Phillips screws securing the camera cable retainer to the upper case.
Remove the camera cable retainer from the upper case.
Lift the black plastic flap attached to the display data cable retainer and rotate it toward the DC-In side of the MacBook.
Pull the display data cable out of its socket.
Remove the two 7.1 mm Phillips screws securing the display data cable retainer to the upper case.
Remove the display data cable retainer.
Remove the two outer 6.8 mm T6 Torx screws from each of the two display brackets (four screws total).
While holding the display and upper case together with your left hand, remove the remaining T6 Torx screw from the lower display bracket.
Remove the last remaining T6 Torx screw securing the display to the upper case.
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
Insert a plastic opening tool underneath the black rubber gasket at the bottom left corner of the display assembly.
Gently pry the wide edge of the gasket up from the back case.
Starting with the freed corner, pull the left gasket off the left side of the display assembly.
Continue pulling the display gasket off the display assembly across the top edge.
Continue pulling the display gasket off the display assembly down the right side.
Pull the gasket off the bottom edge of the display to completely free it and set it aside.
Before starting, be sure to clean the display glass with a lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier.
With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
With the panel sufficiently heated, fasten a heavy-duty suction cup near the lower right corner of the display glass.
To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
Gently lift the corner of the display glass enough to insert a guitar pick between it and the display assembly.
Use the guitar pick to gently pry up the adhesive securing the front glass to the display.
Pry up the glass panel along the right edge of the display up to the halfway point.
Leave the guitar pick in place halfway up the right side of the display and remove the suction cup.
Use a heat gun to soften the adhesive under the display glass along the right and top edges of the display.
Attach a suction cup to the upper right corner of the front glass panel.
Pull up on the glass panel while you use a second guitar pick to separate it from the rest of the display assembly.
Continue working along the right edge of the front display glass until it is separated from the display.
Work along the top edge of the display assembly, carefully prying the adhesive up with the guitar pick.
Stop prying about an inch before you reach the iSight camera. Leave the guitar pick in place and remove the suction cup.
Repeat steps 22 through 24 for the left side and the left top edge of the display.
After prying up the three edges of the display glass, you should have four guitar picks resting underneath the panel, as shown.
With the heat gun set to low, heat the bottom edge of the display to soften the adhesive holding the glass in place.
Slowly lift the top edge of the glass panel and gently rotate it out of the display.
Holding the clutch cover firmly, slide it towards the right display hinge.
Lifting the left edge of the clutch cover, gently rock it back and forth on its long axis while pulling it away from the display.
Remove the clutch cover from the display, minding any cables that may get caught.
Remove the four 2.3 mm Phillips #00 screws securing the LCD to the rear display bezel.
Lift one of the top corners of the LCD panel out of the rear bezel with a plastic opening tool.
Grasp the top corners of the LCD and rotate it upwards, slightly out of the display.
Pull the LCD toward the top of the display panel, freeing the screw tabs from underneath the rear display bezel.
Flip the LCD over and lay it face down, being careful to not put too much stress on the display cable.
Peel the piece of tape covering the display data cable connector away from the edge closest to the LCD.
Use the tip of a spudger to flip up the thin steel retaining clip securing the display data cable to its socket on the LCD.
Pull the display data cable straight away from its socket on the LCD.
Lift the LCD out of the display assembly and set it aside.
Remove the two 2.7 mm Phillips #00 screws securing the camera board to the rear display bezel.
Use the flat end of a spudger to pry the camera board cable from its socket on the underside of the camera board.
Pull the camera/AirPort cable straight out of its socket on the camera board.
3 участников успешно повторили данное руководство.
