Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Nokia Lumia 928 Back Cover Replacement
Curtis Dawe
Curtis Dawe и 2 другие участники
Последнее обновление May 18, 2016
5 мин.
Легко
This very simple guide will teach you how to remove the back cover from your device without damaging it. It is a very quick and easy guide that can be performed by anyone. It involves removing 1 screw and releasing plastic clips inside the phone to remove the back cover.
Выберете то, что вам нужно
Инструменты
  1. Nokia Lumia 928 Back Cover Replacement, Back Cover: шаг 1, изображение 1 из 2 Nokia Lumia 928 Back Cover Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Power down the phone.
    • There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
    • The screw does not come out. Once loosened, It will unlock the lock bar inside the phone. You will break it if you do not complete this step properly.
    • Remove the sim card tray on the top of the phone.
    • Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
    • There is a sticker located on the screw that needs to be peeled off. This voids your warranty.
  2. Nokia Lumia 928 Back Cover Replacement: шаг 2, изображение 1 из 3 Nokia Lumia 928 Back Cover Replacement: шаг 2, изображение 2 из 3 Nokia Lumia 928 Back Cover Replacement: шаг 2, изображение 3 из 3
    • Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
    • It can be useful to flip the plastic opening tool upside down in certain areas of the phone to make releasing the plastic clips easier.
    • Once all the clips are released, remove the back cover of the phone.
Заключение
Curtis Dawe
Участник с: 03/04/16
461 Репутация
Автор 4 руководств
Команду
UMass Dartmouth, Team 6-8, Bhusal Spring 2016 Участник UMass Dartmouth, Team 6-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G8
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 764
