Мой рабочий стол для верстки руководств
Получите быстрый доступ к руководствам, запчастям и ответам касательно ваших устройств
Nokia Lumia 928 Rear Facing Camera Replacement
Curtis Dawe
Curtis Dawe и 2 другие участники
Последнее обновление May 18, 2016
25 - 35 минут
Средне
This guide will show you how to replace the rear facing camera on your device. It has two prerequisite guides. They will show you how to remove the back cover and the motherboard, which will then let you gain access to the rear facing camera. It involves removing some screws, keeping track of a couple different connectors that have to be removed, and patience.
Выберете то, что вам нужно
Инструменты
Показать больше…
  1. Nokia Lumia 928 Rear Facing Camera Replacement, Back Cover: шаг 1, изображение 1 из 2 Nokia Lumia 928 Rear Facing Camera Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Power down the phone.
    • There is a screw located inside the 3.5mm headphone jack that needs to be loosened. Use a Torx T5 screwdriver for this.
    • The screw does not come out. Once loosened, It will unlock the lock bar inside the phone. You will break it if you do not complete this step properly.
    • Remove the sim card tray on the top of the phone.
    • Remove the 4.5 mm Torx T5 screw highlighted with a red circle in the picture. (Note: all screws that you will remove in the phone will be the same)
    • There is a sticker located on the screw that needs to be peeled off. This voids your warranty.
  2. Nokia Lumia 928 Rear Facing Camera Replacement: шаг 2, изображение 1 из 3 Nokia Lumia 928 Rear Facing Camera Replacement: шаг 2, изображение 2 из 3 Nokia Lumia 928 Rear Facing Camera Replacement: шаг 2, изображение 3 из 3
    • Using the plastic opening tools, you can start to release the plastic clips around the phone. Start in the top left corner, work your way down the left side. Then do the top and bottom of the phone, and finally the right side.
    • It can be useful to flip the plastic opening tool upside down in certain areas of the phone to make releasing the plastic clips easier.
    • Once all the clips are released, remove the back cover of the phone.
  3. Nokia Lumia 928 Rear Facing Camera Replacement, Motherboard: шаг 3, изображение 1 из 1
    • Remove all 10 T5 screws on the motherboard. All screws are 4.5 mm Torx T5 screws.
  4. Nokia Lumia 928 Rear Facing Camera Replacement: шаг 4, изображение 1 из 2 Nokia Lumia 928 Rear Facing Camera Replacement: шаг 4, изображение 2 из 2
    • Remove the ribbon connector with a highlighted with a red circle with the plastic opening tool.
    • Be very careful with the ribbon connectors as they can easily be ripped off.
    • The ribbon connector highlighted in yellow has a zero insertion force connector. This has a black flap on the end that needs to be flipped up before the ribbon cable can be pulled out.
  5. Nokia Lumia 928 Rear Facing Camera Replacement: шаг 5, изображение 1 из 1
    • Remove USB port cover using the plastic opening tool, or your hand. It can be removed easily.
  6. Nokia Lumia 928 Rear Facing Camera Replacement: шаг 6, изображение 1 из 2 Nokia Lumia 928 Rear Facing Camera Replacement: шаг 6, изображение 2 из 2
    • Pull up the left side of the motherboard.
    • There is 1 connector that needs to be removed with the plastic opening tool highlighted with a red rectangle. Do not pull the motherboard away from the display assembly until you have removed it.
    • You have now removed the motherboard from the display assembly and the back cover.
  7. Nokia Lumia 928 Rear Facing Camera Replacement, Rear Facing Camera: шаг 7, изображение 1 из 1
    • Lift up the connector for the rear facing camera using the plastic opening tool.
  8. Nokia Lumia 928 Rear Facing Camera Replacement: шаг 8, изображение 1 из 2 Nokia Lumia 928 Rear Facing Camera Replacement: шаг 8, изображение 2 из 2
    • Push the camera out from the side that has the camera housing sticking out (the side in the picture) using the rear end of the plastic opening tool, or your pinkie finger.
    • You have now removed the rear facing camera.
Заключение
Curtis Dawe
Участник с: 03/04/16
461 Репутация
Автор 4 руководств
Команду
UMass Dartmouth, Team 6-8, Bhusal Spring 2016 Участник UMass Dartmouth, Team 6-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G8
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 235
